How do I hide sub categories in the hamburger menu ?
I found the solution here
but I can’t find the show subcategory list in site_settings.
It was moved to the Edit Category dialog. Visit the Category topics, click Edit Category, then under the Settings tab it is Show subcategory list above topics in this category.
OK its working. But I also don’t want to show subcategory list above topics in the category.
Unfortunately, both settings did that, so there isn’t any other way to feasibly get what you want at this time.
There is a pr-welcome to make it easier to hide sub-categories from the hamburger menu though
Enabling “suppress this category from the homepage” doesn’t remove the subcategory from the hamburger menu anymore. I’m on v1.9.0.beta4 +322.
You can do it via CSS which is more consistent
Not really useful for me as it will hide all subcategories.
Then customize the CSS to be (to target the hosting category)
.menu-panel .category-links.category-hosting { display: none }
I’m posting because it should work by using the setting not adding another css hack.
Another way is:
.menu-panel.drop-down .category-link.subcategory {
display:none;
I noticed this code does not work on mobiles, even though I have it in ‘common’ anyone know why?
Already replied here, take a look:
Hi,
Is this the code to remove the “Uncategorized” Category from the hamburger menu?
.menu-panel.drop-down .category-Uncategorized {
display:none;
I am adding it to /admin/customize/themes/9/common/scss/edit, which is our site’s default theme.
It doesn’t seem to be working - help welcome! ![]()
CSS selectors are case-sensitive. The rest of CSS, not so much (read more)
So instead of
display: none;
try
.menu-panel.drop-down .category-uncategorized {
display: none;
Hi @Johani, that worked perfectly. If anyone else is trying to figure out how to hide the uncategorized Category from the hamburger menu, they can try your solution with confidence. Thank you!
