如何在 Ubuntu 中安装 ImageMagick 7 用于开发
In case anyone is devloping in Ubuntu, you can not get the correct version of ImageMagick from an apt repo at the moment.
This means a few integration tests will regularly fail on local.
To get version 7 we have a very simple script you can run which we maintain:
Just download it and execute it.
wget https://raw.githubusercontent.com/discourse/discourse_docker/master/image/base/install-imagemagick
chmod +x install-imagemagick
sudo ./install-imagemagick
Alternatively, use our docker dev image which solves this problem quite nicely:
https://github.com/discourse/discourse/tree/master/bin/docker
13 个赞
