Cómo cargar una copia de seguridad en vivo en el entorno de desarrollo local
How do you load a .tar.gz backup from a live instance into a local dev environment?
Best to use the command line with the backup file. Make sure it has the same filename and put it in backup/default
bundle exec discourse restore
