Hallo,
ich habe ein defektes Discourse-Forum, das ich auf einen anderen Server verschieben möchte. Ich habe ein Backup im folgenden Ordner:
$ ls /var/discourse/shared/standalone/backups/default
$ forum-2019-05-06-033420-v20180920042415.tar
Auf meinem neuen Server versuche ich, das Backup zu laden, aber es schlägt fehl:
$ ./launcher enter app
$ discourse enable_restore
$ gzip public/backups/default/forum-2019-05-06-033420-v20180920042415.tar
$ discourse restore forum-2019-05-06-033420-v20180920042415.tar.gz
Starting restore: forum-2019-05-06-033420-v20180920042415.tar.gz
[STARTED]
'system' has started the restore!
Marking restore as running...
Making sure /var/www/discourse/tmp/restores/default/2019-05-08-180427 exists...
Copying archive to tmp directory...
Unzipping archive, this may take a while...
tar: Unexpected EOF in archive
tar: Error is not recoverable: exiting now
No metadata file to extract.
Validating metadata...
Current version: 20190508135348
Restored version: 20180920042415
Extracting dump file...
EXCEPTION: /var/www/discourse/lib/backup_restore/restorer.rb:264:in `block in extract_dump': Failed to extract dump file.
/var/www/discourse/lib/discourse.rb:29:in `execute_command'
/usr/local/lib/ruby/2.6.0/fileutils.rb:128:in `chdir'
/usr/local/lib/ruby/2.6.0/fileutils.rb:128:in `cd'
/var/www/discourse/lib/backup_restore/restorer.rb:263:in `extract_dump'
/var/www/discourse/lib/backup_restore/restorer.rb:58:in `run'
script/discourse:141:in `restore'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/thor-0.20.3/lib/thor/command.rb:27:in `run'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/thor-0.20.3/lib/thor/invocation.rb:126:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/thor-0.20.3/lib/thor.rb:387:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/thor-0.20.3/lib/thor/base.rb:466:in `start'
script/discourse:282:in `<top (required)>'
/usr/local/lib/ruby/2.6.0/bundler/cli/exec.rb:74:in `load'
/usr/local/lib/ruby/2.6.0/bundler/cli/exec.rb:74:in `kernel_load'
/usr/local/lib/ruby/2.6.0/bundler/cli/exec.rb:28:in `run'
/usr/local/lib/ruby/2.6.0/bundler/cli.rb:463:in `exec'
/usr/local/lib/ruby/2.6.0/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/usr/local/lib/ruby/2.6.0/bundler/vendor/thor/lib/thor/invocation.rb:126:in `invoke_command'
/usr/local/lib/ruby/2.6.0/bundler/vendor/thor/lib/thor.rb:387:in `dispatch'
/usr/local/lib/ruby/2.6.0/bundler/cli.rb:27:in `dispatch'
/usr/local/lib/ruby/2.6.0/bundler/vendor/thor/lib/thor/base.rb:466:in `start'
/usr/local/lib/ruby/2.6.0/bundler/cli.rb:18:in `start'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-1.17.2/exe/bundle:30:in `block in <top (required)>'
/usr/local/lib/ruby/2.6.0/bundler/friendly_errors.rb:124:in `with_friendly_errors'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-1.17.2/exe/bundle:22:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Trying to rollback...
There was no need to rollback
Cleaning stuff up...
Removing tmp '/var/www/discourse/tmp/restores/default/2019-05-08-180427' directory...
Unpausing sidekiq...
Marking restore as finished...
Notifying 'system' of the end of the restore...
Finished!
[FAILED]
Ich weiß nicht, warum, aber das Backup des vorherigen Forums ist defekt, und ich kann nicht mehr auf die Benutzeroberfläche zugreifen, nur auf die Kommandozeile.
Wie kann ich manuell die Datenbank und die Dateien vom vorherigen Discourse auf das neue überführen?
Das tar-Backup enthält Folgendes:
