How to make the CSS apply to ONLY the modified forum homepage?
Solution to Apply CSS Only to Modified Forum Homepage
The original poster, danielabc, wants to apply a CSS modification only to the homepage, but it’s currently affecting all pages. carson provided a solution that involves adding a custom class (custom-homepage) to the html tag when the user is on the homepage.
To achieve this, carson suggests adding a JavaScript code to the head section of the HTML, which uses the api.registerConnectorClass method to create a custom component that checks the current URL and adds or removes the custom-homepage class accordingly.
Once the custom-homepage class is added to the html tag, carson recommends modifying the original CSS code to target only elements with the custom-homepage class:
.custom-homepage #main-outlet-wrapper {
    margin-top: -38px;
This solution allows the CSS modification to be applied only to the modified forum homepage.
I’m making a modification and I want this modification to only work on the HOME, but it’s taking all the pages, how can I leave it only on the home?
i used this
    margin-top: -38px;
  // This is the plugin outlet, followed by a custom name for the component
  api.registerConnectorClass("below-site-header", "custom-homepage", {
    // Setting up our component
    setupComponent(args, component) {
     // Next we're getting the site setting 'top_menu',
     // splitting the values into an array,
     // and adding a leading slash
     var topMenuRoutes =
        component.siteSettings.top_menu.split('|')
        .map(function(route) {return '/' + route});
     // The first page listed in the 'top_menu' setting is your homepage
     // lets assign it to a variable
     var homeRoute = topMenuRoutes[0];
     // This calls our code whenever the page changes
     api.onPageChange((url) => {
        // Check if we're on the homepage
        if (url === "/" || url === homeRoute ){
          // If it's the homepage add the 'custom-homepage' class to HTML tag
          // and set 'displayCustomHomepage' to true
          document.querySelector("html").classList.add("custom-homepage");
          component.set("displayCustomHomepage", true);
        } else {
          // If we're not on the homepage remove the class
          // and set `displayCustomHomepage` to false
          document.querySelector("html").classList.remove("custom-homepage");
          component.set("displayCustomHomepage", false);
</script>
^ Add this to your head to add a .custom-homepage class to your body tag when you’re on the homepage, then →
    margin-top: -38px;
