I setup a localhost for test discourse. When I run
./launcher enter app
to get into the docker as root
how can I add discourse users and emails like
rake admin:create
Thanks.
Users discuss how to manually add users and assign emails via the Discourse console. doudou asks how to create users like rake admin:create after entering the Docker container. elberet provides a Ruby snippet using rails c to create users, approve, and activate them â adding admin: true for admin roles. sam suggests rake admin:invite for inviting admins. trudat asks if new users receive emails â riking advises disabling email via site settings to suppress welcome messages. Jared_Needell seeks a script for bulk users; tonycurzonprice shares a Google Sheets + CSV workaround using load './mail-import.rb' to automate creation. tonycurzonprice and nordize note that users added via console donât trigger welcome emails, even if the setting is enabled â unlike web-created users. optimus asks about assigning users to groups via command â no direct solution is given. thaidb suggests workarounds using invite links. The core issue remains: console-created users are not flagged as ânewâ for welcome emails, despite correct email settings.
rake admin:create
Thanks.
rails c
u = User.create!(username: "name", email: "name@email.com", password: "password")
u.approve(Discourse.system_user, false) # if manual approvals are required
u.activate
If the user should be an admin, add , admin: true to the create line inside the parentheses; likewise for moderators.
Great. It is ok.
Thanks
rake admin:invite is very useful for inviting admins.
Using this method, will the new user receive an invite email?
I am setting up a SSO site and I want to create accounts for all of my existing users without them receiving any email.
Turn on the disable_email site setting before adding the users to suppress the welcome emails.
Anyone have a way to script this for multiple users?
@Jared_Needell - I did a simple kludgey thing for multiple users:
with a csv of all my users, I put them into a google sheet and created essentially this line for each entry with a string formula:
=âu = User.create!(username: 'â&B45&â', email: 'â&A45&â', password: âxxxâ, mailing_list_mode: âtrueâ);u.approve(Discourse.system_user, false) ; u.activateâ
I then put the strings created into a file on the server (mail-import.rb), opened the console and typed:
load â./mail-import.rbâ
It worked a treat
I do have a question about email notifications using this method.
I have added users through the console using the following commands:
u = User.create!(username: âxxâ, email: âxx@xx.comâ, password: âxxxâ, mailing_list_mode: âtrueâ);u.approve(Discourse.system_user, false) ; u.activate
I have enabled âSend all new users a welcome message with a quick start guideâ in http://forum.brickfield.org.uk/admin/site_settings/category/uncategorized
However, emails are not being sent to users being added in this way. They are being sent to users I add through the web front end ⊠(ie itâs not an email problem).
I want the users I add automatically to receive the welcome email - I am migrating a googlegroup and the welcome email will be useful in moving people. So does anyone know how I can alert the system to these added users being ânewâ users from the point of view of receiving the welcome message?
Thank you for any help
Tony
This is helpful! Is there a way to assign the user(s) to groups from command?
we can send an invite user then copy link invite user and create user in other tab
I successfully used Jens Maierâs solution above, but there was no welcome email ⊠I actually wanted a welcome email. Using the latest v1.8.0.beta7 with virtually default docker installation options and emails are working fine otherwise (I get a welcome email if I send an invite from the admin panel).
Any ideas?
