سؤال بسيط: كيف يمكن إجراء الاستعادة عندما يكون لديك حاويات متعددة (بيانات و web_only). حاولت هذا الدليل أولاً من داخل حاوية البيانات:
root@docker2:/var/discourse# ./launcher enter data
x86_64 arch detected.
root@docker2-data:/# discourse enable_restore
bash: discourse: command not found
حسنًا، تطبيق discourse موجود في حاوية الويب. ولكن هنا، تسبب الاستعادة استثناء وتنتهي بخطأ:
Restore are now permitted. Disable them with `disable_restore`
root@forum:/var/www/discourse# discourse restore netzwissen-forum-2023-10-07-125819-v20230913194832.tar.gz
Plugin name is 'discourse-topic-voting', but plugin directory is named 'discourse-voting'
Starting restore: netzwissen-forum-2023-10-07-125819-v20230913194832.tar.gz
[STARTED]
'system' has started the restore!
Marking restore as running...
Making sure /var/www/discourse/tmp/restores/default/2023-10-07-132317 exists...
Copying archive to tmp directory...
EXCEPTION: /var/www/discourse/lib/discourse.rb:138:in `exec': Failed to copy archive to tmp directory.
cp: cannot stat '/var/www/discourse/public/backups/default/netzwissen-forum-2023-10-07-125819-v20230913194832.tar.gz': No such file or directory
/var/www/discourse/lib/discourse.rb:172:in `execute_command'
/var/www/discourse/lib/discourse.rb:34:in `execute_command'
/var/www/discourse/lib/backup_restore/local_backup_store.rb:47:in `download_file'
/var/www/discourse/lib/backup_restore/backup_file_handler.rb:62:in `copy_archive_to_tmp_directory'
/var/www/discourse/lib/backup_restore/backup_file_handler.rb:22:in `decompress'
/var/www/discourse/lib/backup_restore/restorer.rb:42:in `run'
script/discourse:149:in `restore'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.2.2/lib/thor/command.rb:27:in `run'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.2.2/lib/thor/invocation.rb:127:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.2.2/lib/thor.rb:392:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.2.2/lib/thor/base.rb:485:in `start'
script/discourse:290:in `<top (required)>'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/cli/exec.rb:58:in `load'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/cli/exec.rb:58:in `kernel_load'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/cli/exec.rb:23:in `run'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/cli.rb:492:in `exec'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/cli.rb:34:in `dispatch'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/cli.rb:28:in `start'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/exe/bundle:45:in `block in <top (required)>'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/friendly_errors.rb:117:in `with_friendly_errors'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/exe/bundle:33:in `<top (required)>'
Trying to rollback...
There was no need to rollback
Cleaning stuff up...
Removing tmp '/var/www/discourse/tmp/restores/default/2023-10-07-132317' directory...
Marking restore as finished...
Notifying 'system' of the end of the restore...
Finished!
[FAILED]
Restore done.
ما هي الحيلة لجعل الاستعادة تعمل في عمليات النشر ذات حاويات البيانات والويب المنفصلة؟
شكرًا، Thommie
