(Substituído) Redirecionar uma categoria usando regras de permalink
:warning: Please Note
Discourse now automatically redirects renamed categories. I will leave this HowTo up for the time being to cover any eventual edge cases that the automatic redirect doesn’t take into account.
Say you’ve renamed the category /c/school to /c/education and you’d like to make sure all old links that point to https://forum.example.com/c/school will now redirect to https://forum.example.com/c/education. Here’s what you do.
  1. Go to /admin/customize/permalinks:
Here you should enter the partial URL of the category slug that you’re redirecting, in this case c/school
  1. Change the middle drop-down to Category ID
  2. Now, in a separate window, go to your renamed /c/education category and append .json to its URL, so that it looks like this: https://forum.example.com/c/education.json. On this page, search for “category_id”. You’re gonna want to copy & paste this number into your “Category ID” field.
  3. Lastly, enter the ID - in this case 10 - of the category. Before clicking “Add” your form should look like this:
12 Curtiram
Isn’t this process automatic on renaming a category after @techapj’s recent change?
5 Curtiram
I see! The change must not have been deployed yet to Try when I tested it. I tried again today and it does indeed happen automatically, thanks @techAPJ :heart:
I’ve updated the howto accordingly.
6 Curtiram
Para quem está procurando uma maneira de fazer isso, confira isto:
