I want to remove admin logs (admin/logs/staff_action_logs) or disable staff logs?
How to?
No. You can’t disable it.
Why would you want to do this?
I think database larger
Could you safely delete using postgres Sql?
thanks yoú
Take a back-up before you start firing off commands though!
There are very few legitimate reasons to do this…what is the reason?
First, @dangtrungluong , congratulations on having a forum that’s so successful that you actually need to worry about the database size.
However, perhaps you should consider sharding / partitioning?
Generating more granular backups?
Simply deleting data is usually a poor idea likely to lead to unforeseen problems. What exactly is the problem you’re having that you’re wanting to solve?
@Mittineague i’m newbie joining to “discourse”
If you are new to using discourse then I do not see what the issue is at the moment and why you feel it will make a massive impact on your database. We have logs going back to 2014 with no impact and I do not believe it takes up a massive amount of space.
It’s not a bad thing to think about things before they become a problem. If anything, I don’t think the database will be a problem as much as heavy weight media files could be. i.e. should you set up a CDN so the requests are served from closest to a visitors location? Do members reallly need to fill up a topic with mega weight files that could slow down page load and consume bandwidth?
hi. thank for all
Vous pourriez le faire en utilisant la console rails mais c’est aussi dangereux. Donc si j’ai bien compris, cela ressemblerait à ceci :
cd /var/discourse
sudo ./launcher enter app
rails c
Maintenant, vous êtes dans la console, une option pour supprimer toutes les actions du personnel / logs d’administration est d’utiliser ceci :
Cependant, cela supprime tout, ce qui n’est peut-être pas ce que vous vouliez. Vous pourriez vouloir limiter la période de temps ou enquêter sur certaines actions.
Par exemple :
UserHistory.where(action: 17, acting_user_id: 5)
Cela retournerait tous les posts supprimés par l’utilisateur dont l’id est 5.
ou
UserHistory.where(action: 17, post_id: 15643)
Cela retournerait des informations sur qui a supprimé le post avec l’id 15643.
Pour une liste des champs de table et des id d’actions, voir ce fichier :
# == Informations sur le schéma
# Nom de la table : user_histories
# id :integer not null, primary key
# action :integer not null
# acting_user_id :integer
# target_user_id :integer
# details :text
# created_at :datetime not null
# updated_at :datetime not null
# context :string
# ip_address :string
# email :string
# subject :text
# previous_value :text
# new_value :text
# topic_id :integer
# admin_only :boolean default(FALSE)
# post_id :integer
# custom_type :string
# category_id :integer
# Index
# index_user_histories_on_acting_user_id_and_action_and_id (acting_user_id,action,id)
# index_user_histories_on_action_and_id (action,id)
# index_user_histories_on_category_id (category_id)
# index_user_histories_on_subject_and_id (subject,id)
# index_user_histories_on_target_user_id_and_id (target_user_id,id)
# index_user_histories_on_topic_id_and_target_user_id_and_action (topic_id,target_user_id,action)
