איך להסיר את Tos ופרטיות מה-UI?
Hi!
After setting up my self-hosted private Discourse forum, the TOS and Privacy tabs were automatically generated. However, they are misleading and not really applicable for my case. Is there an option to remove/hide them?
Thanks!
Hey @brunall
Welcome to Meta :wave:
The tabs are automatically hidden if the company name site setting is empty.
You can also hide the links at the top of the about page with css:
.nav-pills {
  .nav-item-tos,
  .nav-item-privacy {
    display: none;
Make CSS changes on Your Site
You can also optionally edit change them. Iirc they are located in the Staff Category.
