How do you re-order categories? Like for example, if I have five categories and I want the bottom category to be the top one.
You have to go to the category, hit edit, go to the Settings tab and update the position to a number that places that category where you want.
It used to be possible to do this via drag and drop but that hasn’t seemed to work in a long time.
4 إعجابات
Perfect. Thank you. This can be closed now. Thanks for quick reply.
