Hoe site statistieken opnieuw in te stellen of opnieuw te berekenen?
dear Support,
How to Reset or Recalculate Site Statistics??
I know there is a command you can use to reset the stats, but i dont know if there is a command that recalculate the stats.
Reset the stats:
Destroy site stats
rake destroy:stats
Reference: Administrative Bulk Operations
Thanks @IAmGav but you need to restart the VPS so it will reset and recalculate automatically!
Thanks for Your Help!
rake destroy:stats
above command reset the admin panel statistics only!
