How to revert from initial bad color configuration
I rushed to set few colors and icons right after initial install - and now I really to not like it (here is a sample)
I know that with an empty site, the simplest thing would be to run ./launcher rebuild app in the console, but I would like to be able to change some minor look and feel properties even when rebuild is not a feasible option.
Hi!
you’ll find the color schemes there:
https://your.domain/admin/customize/colors
and then within your themes here:
https://your.domain/admin/customize/themes
Thank you for responding @Benjamin_D and allow me one more question: is there some support for undo/redo for these (https://your.domain/admin/customize/colors and https://your.domain/admin/customize/themes) or am I on my own and my knowledge of CSS?
It looks like you selected this color palette when you went through the wizard.
I think a couple of the colors in that palette have regressed - leading to low contrast. I’ll get those fixed.
For now, you can always go through the wizard (initial configuration) on your site at any time by visiting:
your.site.com/wizard
This will allow you to select another color palette and change the icons without any CSS knowledge.
Great explanation, thank you @Johani
