How to seed local database with SSO user data
I’ve got a client that I’m doing an import for. They’re using SSO, which will supply avatars, but of course those get populated only when someone logs in. I noticed client.sync_sso and it appears to do just what I need. I think I’d like to do this from the API, but rails console would be fine too.
I thought that client.sync_sso would work, but it appears to push SSO data, not pull SSO data.
Is there some way that I can suck down the SSO data for each user? It doesn’t look like the API will help, maybe something in the console? Looks like lookup_or_create_user might help, but I can’t find the external_id.
I have done exactly this.
What I did was getting the user database, and created all the users using the API.
That sounds like what I’m looking for @Falco. Are you saying that I should create all the users from the API before I run the import script that creates the users, or that I should somehow use an API call in the import script to create the user?
Can you point me to some code?
I would create the users during the import, and set the avatar at import time also.
You need to ask for a dump that also contains avatars urls.
I believe I have the URLs. Since avatars get populated when someone logs in, I was thinking that I could use the API (or console) to suck them down from SSO. The importers I’d looked at were uploading the avatars (which I don’t have), but now I see that I can pass a avatar_url to create_users, which should solve my problem.
Thanks.
