כיצד להציג את שם המשתמש ליד האווטאר בניווט כאשר מחובר?
סיכום מבוסס בינה מלאכותית
asugar is looking for a way to show a user’s name next to their avatar in the navigation bar when logged in. Arkshine provided a custom HTML/CSS solution using a theme component, which includes a script to add the username and CSS to adjust the layout. This solution is disabled on mobile view and may require adjustments for non-default themes. asugar confirmed that the solution works as expected.
Hello All,
Is there a way to show user’s name in the navigation bar next to avatar when user is logged in. See the screenshot below.
Hello, welcome back Auston!
Could you try this custom HTML/CSS, please?
This should work fine with all notifications badges with/out the new notifications menu enabled.
I suggest you create a theme component. In case you don’t know, everything is explained here: Beginner's guide to using Discourse Themes
Note: It’s disabled on mobile view.
Note: CSS is based on the default theme; you might need to adjust it. Feel free to ask.
I did not test extensively, but I hope this will work for you!
Head
<script type="text/discourse-plugin" version="0.8.13">
api.decorateWidget('header-notifications:after', dec => {
    const { currentUser, site } = dec.widget;
    if (site.mobileView) {
        return;
    return dec.h('span.username', currentUser.displayName);
</script>
CSS
html:not(.mobile-view) #current-user {
    span.username {
        display: inline-block;
        vertical-align: middle;
        margin-left: 5px;
    .icon.btn-flat {
        width: auto;
    .user-status-background {
        left: 22px;
    .badge-notification {
        &.with-icon.new-pms {
            left: -3px;
            right: auto;
            top: 4px;
    .unread-notifications {
        left: 25px;
        right: auto;
    .unread-high-priority-notifications,
    .ring {
        left: -3px;
        right: auto;
Thanks a lot. It works :slight_smile:
