Hoe 'Automatisch sluiten'-waarschuwing onderdrukken tot dichter bij de sluitingsdatum?
Laura_S is looking to suppress the ‘auto close’ warning on her forum until a thread is closer to its close date or suppress it entirely. She wants to prevent users from reviving ancient topics while still allowing ongoing discussions. JammyDodger suggests reducing the auto-close timer to a month after the last reply, but Laura_S is more concerned with suppressing the warning message.
According to pfaffman and JammyDodger, the warning can be hidden using CSS. JammyDodger provided the CSS code to hide the topic-timer-info and explained how to add it to the site. However, it’s not possible to make the warning reveal itself when the due date is near.
Is there a way to suppress the ‘auto close’ warning until the thread is getting closer to the close date and/or suppress it totally?
I don’t want to stifle discussion, but we also have had a problem with folks reviving ancient topics (despite the warning on topics older than 90 days) so we’re just rolling out auto-close now.
I think that particular timer will reset to a year every time someone posts? Would reducing that to a ‘month after the last reply’ be a better fit?
We don’t tend to have a lot of ‘ongoing’ topics but there are a few that are which is fine.
I mostly just want to limit people picking up threads that have been dormant for more than a year which this should cover.
But I was more wondering about how to suppress the ‘warning’ at the bottom.
You can just hide it with CSS. There are a bunch of topics about hiding other stuff (search “hide css” if you want to figure it out, but hopefully someone else will give you an actual answer.
With the ‘after last reply’ ones, the timer gets reset when someone replies So if you had ‘1 year after the last reply’ it will stay open for at least a year, but would also continue for another year if someone posted again (eg. a post out of the blue on day 364 would reset the count to the full year again). There is the option to just have a straight ‘this topic will close in 1 year’, which won’t reset when people post more replies.
I thought perhaps having a shorter ‘after the last reply’ timer may solve your issue with not wanting a huge time duration displayed at the bottom. The topic would still stay open for as long as people were replying + the timer duration.
As @pfaffman says, you can hide the topic-timer-info with a little CSS, but I don’t think you can easily make it reveal itself when it gets closer to the due date.
.topic-timer-info {
    display:none;
Extra details on how to add it to your site
  • Go to /admin/customize/themes
  • Click on install and then create new
  • Give it a name, and select ‘component’.
  • Create
  • Add it to your theme
  • Click on the Edit CSS/HTML button and paste the code into the Common tab
And save. :+1:
