How to use apply_custom_query from topic_query.rb on review page topics in plugin
סיכום מבוסס בינה מלאכותית
Oliver_Walker is seeking help with applying a custom filter to topics on the /review page using the apply_custom_query method from topic_query.rb in a plugin. The filter currently only works on the default topic view. After further investigation, Oliver_Walker realized that reviewables do not use topic query functions, making it impossible to apply the custom filter this way. They are now considering overriding the reviewables_controller#index function to remove topics from the reviewables list based on the current user. Oliver_Walker welcomes advice and suggestions on this approach.
hello,
I have a plugin that makes use of the TopicQuery.add_custom_filter function.
It applies my custom filter as expected only to the default view of topics displayed on the landing page.
I noticed this is because in the topic_query.rb file under the defualt_results method there is a call to apply my custom filters with
    result = apply_ordering(result, options)
this is great, but not exactly what I wanted. I wanted to have that filter applied to anything showing up under the /review page. I’m not sure how I would do this.
is anyone familiar with this part of the code?
the way I am currently filtering can be seen here:
https://github.com/hms-networks/discourse-location-filters/blob/test/app/controllers/filter_controller.rb
and the discourse rb file I am talking about is this one:
I guess I messed up when I started going down this topic query path because it looks like reviewables doesn’t even use those topic query functions so I cant apply a custom filter this way.
also, I am still a little confused about what the parameters of apply_custom_filters are. do results refer to a ruby hash of topics? and is topic_query just an instance of the class?
Moving forward I’m not sure if this is the correct way to do this but I will try to find out how I can overwrite the reviewables_controller#index function to remove topics from the reviewables list depending on the current user.
advice and suggestions here would be cool :slight_smile:
