It’s said in this post on customizing personal styles that it’s not possible to use an <a> link tag directly because it’s an exception and doesn’t allow any data-attributes.
The solution is to use a Markdown [link] to enable the use of attributes, just like this :
Code :
This <span data-button>[link](https://discourse.org/)</span> use Mardown !
Result :
This link use Mardown !
However, for the structure of this specific post (and even for the all discourse), I need to use <div> in html for ease of use, but this seems to prevent any BBCode or markdown from being corectively interpreted. So using markdown links doesn’t work directly in a div.
Code :
<div>
This <span data-button>[link](https://discourse.org/)</span> use Mardown in a div !
</div>
Result :
This [link](https://discourse.org/) use Mardown in a div !
I find myself unable to use <a> tags, which prevent data-atributes, and unable to use markdown or BBCode, which only work outside divs.
Can anyone suggest a solution ? Thank you so much.
