How to use custom OAuth verification with DiscourseConnect?
lawmixeraintalive is seeking guidance on implementing custom OAuth verification with DiscourseConnect to sync user data from Roblox, including public and private user fields like “Group Rank” and “Discord Id”. They shared a Python/Quart code snippet attempting to return user data (username, avatar, etc.) alongside custom fields but are unsure how to properly structure or encode the payload for Discourse, particularly regarding user field visibility (public/private) and whether base64 encoding is required 6. They also referenced a screenshot of the user profile UI where these fields should appear 2. Despite multiple follow-ups 4, 5, no solution has been found yet. The core questions remain: (1) Is base64 encoding mandatory for the return URL? (2) Is their current dictionary return format sufficient for Discourse to process user fields correctly?
I’m in the middle of trying to switch everything over to use my OAuth methods, and Discourse is the last thing on my list.
The things would love to complete if it is a feature:
  1. How would I create public/private user fields to display in their user page about them? Like Group Rank for anybody to see, but like Discord Id for only admin and moderators can see (also API)?
Also, how would I implement this in python using Quart? This is some code that I programmed, though the documentation is very unclear on to pass data for Discourse and how too including User Fields, and trying to make them not so users can edit them.
from quart import Quart, redirect, request
from rblxopencloud import OAuth2App, Group
from roblox import RobloxUser
oauth_app = OAuth2App("ROBLOX_APP_ID", "ROBLOX_APP_SECRET", "ROBLOX_APP_REDIRECT")
app = Quart(__name__)
@app.route("/")
async def authentication_verify():
    return redirect(oauth_app.generate_uri(["openid", "profile"]))
@app.route("/authentication/redirect")
async def authentication_redirect():
    roblox_info = oauth_app.exchange_code(request.args.get('code'))
    group_member: Group = RobloxUser.fetch_member(roblox_info.user, 4800717)
    group_rank = "Test Subject"
    if group_member != None:
        group_rank = group_member.fetch_role().name
    discord_id = "this-will-pull-from-my-db"
    return {
        "permalink": roblox_info.user.username,
        "username": roblox_info.user.username,
        "uri": roblox_info.user.profile_uri,
        "avatar_url": roblox_info.user.generate_headshot(size=420, format="jpeg", is_circular=True),
        # These I would like to be user fields (either public or private)
        "group_rank": group_rank,  # Public User Field
        "discord_id": discord_id,  # Private User Field
        "roblox_id": roblox_info.user.id, # Private User Field
app.run(host="host-ip-here", port=0000)
Whenever I talk about User fields, I mean this that is in the User profile link:
bumping this as I need help still.
Still need help on this - Haven’t figured it out yet.
Update on my question:
  1. Do I have to encode the URL with base64 or can I just leave it normal without encoding it?
  2. How would I return data? Is it something like:
return {
