I am not familiar with rails so much and I want to code a plugin that asks user his job and fill the job’s user_custom_fields(already created manually) in the database.
Because I’m familiar with PHP, I add new rows to database directly by SQL Queries (Like what we do in PHP) But this won’t increase the sequence table and this may cause some damages to site.
I have tried to increase the sequence table but postgres didn’t allow me to change data in _seq tables.
I have two solution:
1-get the permission to edit rows in _seq tables and change them with SQL Query.
2-edit or add the database using rails methods.(that increase the _seq tables automatically)
Surely, the second solution is the best but this solution is good for who are familiar with rails and MVC and for me and as a temporary solution(to avoid big harms) the first solution is good until I learn how to code with Rails.
So how Can I solve this problem? What is your Idea?
Adding a new row or editing older rows in Ruby On Rails isn’t like PHP because Rails is so much objective even when you want to work with database.
I will explain my answer for other who have my problem:
FORGET about sql query, in Here everything are objects, every row in database is an object. for adding a new row, you should create a new object and if you want to edit a row, you should find that row as an object.
So if everything is object here, What is the class name for creating new one?
If you want to edit the user_custom_fields table, the class name is UserCustomField.
to edit an exiting data, you should find it first like this:
this code will change the custom_user_field with name user_field_5 and user_id 364 .
now for adding new one you should do this:
NewObject = UserCustomField.create(user_id: 634, name: 'user_field_6', value: 'my value')
this code will create a new row in database and you shouldn’t define id, created_at , updated_at because rails will define them automatically and also increase the sequence.
