Manipulating custom user fields from the Rails console
Manipulating Custom User Fields from the Rails Console
The original poster, nathank, attempted to bulk replace data in a user custom field using a code snippet derived from the Ning importer. However, this resulted in wiping the users’ other custom field values.
JammmyDodger suggested a modified version of the code that only changes the specified custom field, using u.custom_fields["user_field_16"] = "Nil" instead of u.custom_fields = {"user_field_16" => "Nil"}.
fzngagan explained that the original code replaced the entire u.custom_fields hash, which is why other custom field values were lost.
nathank confirmed that using u.custom_fields["user_field_16"] = "Nil" was the correct approach.
pfaffman offered alternative methods for creating or updating custom fields using UserCustomField.create and UserCustomField.find_by.
nathank shared a useful tool for getting the Rails syntax right when manipulating custom fields in the Rails console, including a placeholder template for replacing or filling custom field data.
Other users, including j127 and Kuro22, discussed the dynamic content in the post, with Kuro22 linking to a meta post about placeholder forms.
I used this code snipped to attempt to bulk replace some data in a user custom field. I derived it from the Ning importer.
users=User.where("users.created_at <= '2019-09-13'::timestamp")
users.each do |u|
  u.save
However it had the unintended consequence of wiping the users’ other custom field values.
Can anyone suggest a way to modify a user custom field value from the console that doesn’t cause chaos?
I think this format changes only the custom field in question. I’ve tested it briefly, and it seemed to do the trick. :+1:
users.each do |u|
  u.save
Though if you wanted the field to be NULL rather than say ‘Nil’ you could try this instead:
users.each do |u|
  u.custom_fields["user_field_16"] = NIL
  u.save
Also something like
UserCustomField.create(user_id: 1, name: "user_field_4",value: "Oops")
Oh, but if that already has a value, it’ll add a second one! So you might
 ucf=UserCustomField.find_by(user_id: name: 'user_field_4')
and then you’d need to either update it or create a new one.
But if you do create multiple ones, the UX will show them comma-separated, and if they are edited via the UX when they get saved, they get saved back to a single value.
You can have a look at them with
  UserCustomField.all
Or
UserCustomField.where(name: x)
That’s by memory on my phone so your mileage may vary.
By doing this, you’re replacing everything in the u.custom_fields hash with {"user_field_16" => nil}(note the nil without quotes)
Thank you - yes, that is what I should have used.
Yup, that is exactly what happened. I felt pretty foolish afterwards!
I find this a useful tool for getting the rails syntax right when you want to manipulate these UCFs in the Rails console:
If you are replacing data in that field
UserCustomField.find_by(user_id: =UserID=, name: "=UserFieldName=").update(value: "=NewValue=")
(will give you an error if there isn’t any data in that field yet)
If you are filling that field for the first time
UserCustomField.create(user_id: =UserID=, name: "=UserFieldName=",value: "=NewValue=")
How did you create that dynamic content in the post?
It seems that meta has this component on. (Just guessing
