I want to educate some users on using code fences for posting code.
How can I post three ticks (```) as text without the “after one tick mark text as preformatted”?
סיכום מבוסס בינה מלאכותית
The discussion revolves around how to display three backticks (```) as plain text in a post without triggering code formatting. Sujan seeks a way to include `````` in-line, as it’s automatically interpreted as a code fence. codinghorror suggests using four spaces before the ticks or escaping them with a backslash (ackslashackslashackslash). clapmyhands proposes using <code>ackslashackslashackslash</code> to display the ticks with a gray background. Sujan confirms this works and notes a potential bug in the quote engine where backslashes are lost. clapmyhands explains how to create a new topic from a post using the chain icon. Sujan reports the bug and concludes the discussion satisfied with the solution.
Actually directly inside a line of text, so I can post something like
I edited your code to display better. Please use
(three ticks)in the line in front and after your code to enable this formatting yourself. Thanks.)
But with the three ticks instead of “(three ticks)” of course.
(Man is it hard to describe this if every try to actually type it gets removed ;))
It’s very, very tricky to get that right inline. Another way is backslash
Testing: ```
That works, thanks.
Good luck with that ![]()
To make it even more complicated:
Is there a way to preformat the three ticks now in line? So we have this nice grey background to make the command stand out…
Try this ```
Using so:
<code>\```
Edit: forgot to close tag ![]()
Fancy².
Let’s see if this works to output the three ``` (```) needed to format code. Yes it does. Didn’t know about <code> before. Thanks!
PS: Uh, did I just discover a “bug” in the quote engine? Backslashes are gone…
Back slash where?
Inside your bracket?
I quoted your <code>\``` in my response. There it shows without the backslashes.
Super edge case of course, but [quote] seems to miss the \ on output.
Oh.. that might be a separate bug but we can ask @codinghorror
Maybe raise a new bug topic.
But it seems your use case is covered for now ![]()
Cheers
Done: [quote] loses backslashes on this super edge case
And yes, I’m happy with my solution. Thanks!
What kind of sorcercy…
Awesome. Thanks.
