I’m working on a few templates for the global notice banner, but the href does not work. I can see that the color changed for this <a> tag, but nothing happens when I click the link. Is that a bug or a feature?
Thanks!
dawid_matuszczyk reported an issue where href links in the global notice banner were not clickable, despite the text color changing. Firepup650 asked for clarification, noting that emergency banners usually work. After confirming the issue persisted, Arkshine requested the HTML code and demonstrated that the feature worked on their end, suggesting a potential syntax error. dawid_matuszczyk resolved the issue, identifying that the macOS Notes app was inserting curly quotes (“ ”) instead of straight quotes (`
Thanks!
Are you referring to the “emergency” banner? a hrefs worked there last I checked.
Yes! The link is not “clickable”
It does work for me if you mean the global notice setting. ![]()
What is your HTML?
Thanks! It works now. I think the macbook notes app is placing the wrong " sign.
You may be right! It’s likely “quote” instead of "quote".
I’m glad it works now! ![]()
