HTML diff view is a bit broken
See the screenshot for a diff on an edit I made. Actually multiple edits, which might be a contributing factor, but combined into one historically (I guess due to being within a five minute window or such).
The meat of the edit is the adding of the last paragraph. But the diff algorithm seems to have latched on to some words in that paragraph that are in the first point in the bulleted list and then kept drawing the wrong conclusions.
The markdown view is more reliable :wink:
Yeah, just switch to Markdown view.
Ok, changing the title.
So in this case, just the last para was added? No other edits/changes? Ironically I can’t tell. Can you post a screenshot of the markdown diff?
Yeah, sorry. :slight_smile: Markdown diff below; the text at the end was added.
「いいね!」 2
古いスレッドであることは承知していますが、この問題はまだ解決されていないと思います。そして、それはHTMLの差分だけではありません。これは私のトピックからのものです。
ご覧のとおり、画像(したがってinsだと思います)の後に改行を追加しただけです。しかし、3行がハイライトされており、これは不要なようです。空行を削除した場合も同様で、delが表示されます。
