I recently enabled letsencrypt for my instance by following this tutorial.
Now all the images uploaded via settings panel (logo, small logo, favicon) have http links in the design, resulting in mixed content error (although user avatars and uploads have correct https links). Reuploading them doesn’t change anything.
Was this server built using the standard install guide, or some other third-party package?
Is :80 specified in your app.yml at the end of the domain name? Check DISCOURSE_HOSTNAME - it shouldn’t include the port, but likely does based on what you’re reporting above. Remove the :80 from that line if so and rebuild. The only place :80 should appear in the YML file is the expose: section.
Force_HTTPS is required when Let’s Encrypt is enabled, the mixed content error is the result of an install without it enabled.
It was previously a bitnami install. The domain was the same, but SSL wasn’t enabled. I set up a new VPN, did the standard install, then migrated the data via the admin export/import feature. Then I enabled letsencrypt and rebuilt.
DISCOURSE_HOSTNAME is community.mysite.com. expose is the only place where 80 appears. Here’s my full config (some details censored):
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
- "templates/web.ssl.template.yml"
- "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
- "80:80" # http
- "443:443" # https
params:
db_shared_buffers: "768MB"
#db_work_mem: "40MB"
#version: tests-passed
env:
LANG: en_US.UTF-8
UNICORN_WORKERS: 2
## Required. Discourse will not work with a bare IP number.
DISCOURSE_HOSTNAME: community.mysite.com
## Uncomment if you want the container to be started with the same
## hostname (-h option) as specified above (default "$hostname-$config")
#DOCKER_USE_HOSTNAME: true
DISCOURSE_DEVELOPER_EMAILS: censored
## TODO: The SMTP mail server used to validate new accounts and send notifications
# SMTP ADDRESS, username, and password are required
# WARNING the char '#' in SMTP password can cause problems!
DISCOURSE_SMTP_ADDRESS: smtp.sendgrid.net
DISCOURSE_SMTP_PORT: 587
DISCOURSE_SMTP_USER_NAME: censored
DISCOURSE_SMTP_PASSWORD: censored
#DISCOURSE_SMTP_ENABLE_START_TLS: true # (optional, default true)
## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
LETSENCRYPT_ACCOUNT_EMAIL: censored
## The CDN address for this Discourse instance (configured to pull)
## see https://meta.discourse.org/t/14857 for details
#DISCOURSE_CDN_URL: //discourse-cdn.example.com
volumes:
- volume:
guest: /shared
- volume:
guest: /var/log
## Plugins go here
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
run:
This might seem like an odd question, but why wouldn’t you enable Let’s Encrypt prior to restoring your data?
Let’s Encrypt is part of the standard install, you almost have to go out of your way to not do it during setup. Enabling it prior to restoring a backup would let you verify that you have a known-good install with working SSL prior to re-introducing your data.
I don’t have much experience with discourse. I didn’t know I was supposed to enable SSL prior to importing data. I thought that importing might overwrite some settings.
The hostname and protocol are configured in the app.yml, which isn’t included in backups. Providing the backup file isn’t renamed it can be restored to another instance even if the FQDN doesn’t match.
I would work on getting Let’s Encrypt working with a standard install, then upload the backup, enable restore and restore your data.
I tried a a fresh install on a new vps, but it broke again after importing data. After lots of googling and going through source code, I found out my Discourse.BaseUrl had port 80 forced into it. I tracked it down to these lines in discourse.rb:
As a temporary fix, I commented out the last line, rebaked all the posts and that fixed everything for me.
Then I looked at my sql dump from the previous site export, and found out that port was set to 80 in site_settings (as I’ve mentioned, the original install didn’t have SSL). It didn’t match the port 443 which is expected from a site with force_ssl, and 80 was inserted into BaseUrl. So, I guess the proper fix is to change SiteSetting.port to 443 and then rebake.
This is a developer only setting, how did it get set? Discourse itself does not support running in production mode on any any ports other than the standard ones.
Tive um problema semelhante após migrar para uma configuração de dois contêineres com nginx como proxy reverso de front-end para um socket Unix.
Tudo funciona perfeitamente, exceto que o Discourse não estava alterando http para https no código-fonte e o nginx não reescrevia/redirecionava isso.
Após muita investigação e dias de tentativa e erro, finalmente encontrei esta configuração de linha de comando:
cd /var/discourse
./launcher enter socket-only
rails c
SiteSetting.force_https = true
e verifiquei:
postgres=# \c discourse
Você agora está conectado ao banco de dados "discourse" como usuário "postgres".
discourse=# select * from site_settings where name like '%http%';
id | name | data_type | value | created_at | updated_at
79 | force_https | 5 | t | 2020-04-16 05:51:13.165124 | 2020-04-16 05:51:13.165124
(1 row)
discourse=# \q
Em seguida, reiniciei:
./launcher restart socket-only
BOOM.
Funcionou, finalmente, após dias de confusão e tentativa e erro, me perguntando por que todos os tutoriais, guias e READMEs na internet não funcionavam perfeitamente.
Isso deve ser como uma joia escondida em um videogame, e apenas os jogadores que encontram o poder oculto podem passar para o próximo nível!! LOL. Eu estou lá! Um novo superpoder do Discourse!
