Ich kann die Abstimmung nicht aktivieren
Hi!
I’ve install the voting plugin, I see the checkbox to enable voting in the category parameters but when I check it to enable voting it doesn’t save correctly.
Re-opening category settings show me the setting unchecked.
Did I miss some config stuff after plugin install or something?
Just after saving category settings I can see this error in /logs
Uncaught Error: Property set failed: object in path "custom_fields" could not be found.
Url: https://forum.example.com/assets/ember_jquery-5dbd79abddf53926275c73f77dbe61e7351258de8d2e886bf2ce86f144378598.js
Line: 6
Column: 27777
Window Location: https://forum.example.com/c/my-category/my-subcategory
What version of Discourse are you running?
it’s version v2.3.0.beta5 +175 with :
and
40
I am not reproing this here @vinothkannans can you have a quick look to see the serializer is adding custom_fields even if there are none, can you test this on local?
My fault! It’s not adding it. Fixed in commit
https://github.com/discourse/discourse/commit/b8bd031648afa17fb3952dea17f54ec8c9c30caf
Thanks a lot! it’s working fine now, but there is another glitch.
Just after enabling votes for a category, I can see that all topic have 1 vote in the list, but 0 on a topic thread.
@vinothkannans is this also coming from the serializer changes?
I don’t think so. I will check now.
It is French translation related issue. I fixed the English locale file in below commit. I will fix the French translation in Transifex and let you know here.
https://github.com/discourse/discourse-voting/commit/412320b06e02260fcc302451fc48f8eefc988a77
Thank you for your availability and your efficiency :+1:
French translation is updated.
Are any other translations going to be in a similar state?
