I have error when try to rebuild app
I have this error when try to rebuild app. I 've never seen it before
I tried to reboot, but then this error is still there
$: ./launcher rebuild app
HEAD is now at d1db030 cut a new version
I, [2021-08-30T10:45:51.096586 #1]  INFO -- : Loading --stdin
I, [2021-08-30T10:45:51.102601 #1]  INFO -- : > locale-gen $LANG && update-locale
I, [2021-08-30T10:45:51.173412 #1]  INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2021-08-30T10:45:51.173963 #1]  INFO -- : > mkdir -p /shared/postgres_run
I, [2021-08-30T10:45:51.176980 #1]  INFO -- :
I, [2021-08-30T10:45:51.177439 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2021-08-30T10:45:51.180188 #1]  INFO -- :
I, [2021-08-30T10:45:51.180610 #1]  INFO -- : > chmod 775 /shared/postgres_run
I, [2021-08-30T10:45:51.182946 #1]  INFO -- :
I, [2021-08-30T10:45:51.183287 #1]  INFO -- : > rm -fr /var/run/postgresql
I, [2021-08-30T10:45:51.186650 #1]  INFO -- :
I, [2021-08-30T10:45:51.187032 #1]  INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2021-08-30T10:45:51.190969 #1]  INFO -- :
I, [2021-08-30T10:45:51.191391 #1]  INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
I, [2021-08-30T10:45:51.218392 #1]  INFO -- : postgres already running stop container
FAILED
Pups::ExecError: socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1 failed with return #<Process::Status: pid 35 exit 1>
exec failed with the params "socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1"
e9aa4286bc2f13a785e2be5d148485f1fca4a27de84256071f4ad53d029883a9
