Ich möchte meta name="description" entfernen, aber die Änderungen werden nicht übernommen
I want to remove the meta name=“description”, i had made changes in application.html.erb
The file is located at :
/var/lib/docker/overlay2/77f62fc5de6c7f76b807f77a0b2ad6fd1cfd6377d452e4fec0349278c8aca505/diff/var/www/discourse/app/views/layouts/application.html.erb
But changes not reflecting…
Is this is a correct file path ?
What steps I have to do after made changes…
You are trying to make changes to the Docker container. However, they are short-lived. As soon as you update any component of the site, the file will change.
In your case, you may have made a mistake with the folder:
/ var / lib / docker / overlay2 /***???**
If the file is correct, the changes should occur after: ./launcher restart app
What would be the correct path?? I had installed over digitalocean.
I think it is:
