Lightbox de imágenes no funciona en instalación en subcarpeta
I see that some images on this forum have an image lightbox where you can click on an image thumbnail and view the original image. Is there an admin setting to enable this as it does not appear to be working on our forum? I couldn’t anything relevant when searching the settings or this forum.
See Getting Tag-Informations from BuildChangeset does not work - VSoft Technologies Forums. The first image is 1307x207 and the markup (which was automatically generated when pasting the image into the editor) is ![image|690x120](upload://dOXrmMRj5KCpDAg2GftoG5fZrMa.png). The original image is available If I right-click and open the image in a new tab but there is no light box available when I click on the image.
The setting is called ‘create thumbnails’. It is enabled by default. When enabled, it will create thumbnails and lightbox images that are too large to fit in a post.
The ‘create thumbnails’ setting is enabled. It appears to be creating thumbnails but not linking to a light box. We are running the latest version 2.2.0.beta4 +238
This implies your Discourse is not set up correctly, primarily because the background sidekick tasks necessary to do the background image work are not running.
I guess this could be related to our subfolder install :roll_eyes: (which is otherwise working very well).
If I navigate to /forums/sidekiq I just get forbidden.
This is our app,yml with the recommended mods for subfolder installation :
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
##  - "templates/web.ssl.template.yml"
##  - "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  - "80:80"   # http
  - "443:443" # https
  - "5432:5432" #postgres
params:
  db_shared_buffers: "128MB"
  upload_size: 20m
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LANG: en_US.UTF-8
  UNICORN_WORKERS: 4
  ## Required. Discourse will not work with a bare IP number.
  DISCOURSE_HOSTNAME: www.xxxx.com
  DISCOURSE_RELATIVE_URL_ROOT: /forums
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: 'vincent@xxxx.com'
  ## TODO: The SMTP mail server used to validate new accounts and send notifications
  # SMTP ADDRESS, username, and password are required
  # WARNING the char '#' in SMTP password can cause problems!
  DISCOURSE_SMTP_ADDRESS: mail.xxxx.com
  DISCOURSE_SMTP_PORT: 25
  DISCOURSE_SMTP_USER_NAME: vincent@xxxx.com
  DISCOURSE_SMTP_PASSWORD: "xxxx"
  DISCOURSE_SMTP_AUTHENTICATION: login
  DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
  LETSENCRYPT_ACCOUNT_EMAIL: vincent@xxxx.com
  ## The CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
  #DISCOURSE_CDN_URL: //discourse-cdn.example.com
  # RATE LIMITING
  DISCOURSE_MAX_REQS_PER_IP_MODE: 9999999
  DISCOURSE_MAX_REQS_PER_IP_PER_MINUTE: 999999
  DISCOURSE_MAX_REQS_PER_IP_PER_10_SECONDS: 999999
  DISCOURSE_MAX_ASSET_REQS_PER_IP_PER_10_SECONDS: 999999
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone https://github.com/discourse/discourse-voting.git
          - git clone https://github.com/discourse/discourse-solved.git
run:
  - exec:
      cd: $home
      cmd:
        - mkdir -p public/forums
        - cd public/forums && ln -s ../uploads && ln -s ../backups
  - replace:
      global: true
      filename: /etc/nginx/conf.d/discourse.conf
      to: |
        rewrite ^/(.*)$ /forums/$1 break;
        proxy_pass http://discourse;
  - replace:
      to: |
        etag off;
        location /forums {
            rewrite ^/forums/?(.*)$ /$1;
  - replace:
      to: $http_x_real_ip
      global: true
Subfolder installs are notoriously difficult to configure. Hence the warning in the subfolder guide:
Best guess, something is not configured correctly with your proxy.
Yes, yes, subfolder… I know (I spent a day getting it working). Surely if you are so against subfolders you would remove the guide and say absolutely not supported? It seems like it’s mostly there, so why wouldn’t you help resolve the issues as they are found and update the guide? In the end there would less topics like this, and more people using discourse.
I can navigate to /forums/logs ok, so I guessing something needs to change in the routing for sidekiq web?
Seeing this occurring a lot :
Job exception: Failed to open TCP connection to localhost:8080 (Cannot assign requested address - connect(2) for "localhost" port 8080)
I can confirm that sidekiq is running (and scheduled backups are still working).
You’re talking about the fundamental difference between sharing information and offering best-effort support. One doesn’t mandate the other.
The choice to share information to get you started with something doesn’t create any onus or responsibility to support it. We’ve suggested several times that you’re choosing to walk an unnecessarily painful path, this is another of those pain points - it almost certainly won’t be the last.
In 2018 there’s no good reason to run subfolder, which you’ve heard from us previously, it’s not deterring anyone from deploying the software.
@Stephen It just seems odd that each topic that has any info about subfolders get’s the standard “subfolders, world of hurt” type reply, when really there is usually something to be learned from the topic.
I also get that this is open source/free etc and we’re ‘on our own’ since we’re hosting it ourselves.
My recommendation would be to remove all references to subfolder installs, then no one will be enticed by a guide that looks doable at first glance.
As @jomaxro already quoted, the support statement is right there in the howto for subfolder. I don’t think it needs to be hidden, it’s there for any hosted enterprise customers or sites willing to accept the likelihood for complications, which you did when you read the document and continued down that path with your install.
All your experience has really done is prove that point. The team are very honest about what Discourse can and can’t do, all of the recommendations are there to give would-be administrators and developers a chance to enjoy and succeed with the product.
For those who choose to go off the beaten track the odd ‘thar be dragons’ sign is erected. The thing about dragons is that for the right price someone is usually willing to assume the time and risk to come kill them.
Whatever you do don’t mention the subfolder! https://www.youtube.com/watch?v=yfl6Lu3xQW0 :slight_smile:
I won’t promise to have looked carefully at all of this, but Discourse should be on a non-standard port so that your external web server can do the reverse proxying. So I’m confused how it’s working at all. Can you really access other stuff on the server at, say https://yourodmain.com/?
My suggestion was going to be to try to curl http://localhost:PORT/sidekiq to see if you could access sidekiq.
@pfaffman Pretty much everything else is working, you can see it here at https://www.finalbuilder.com - website, forums etc all accessible. /forums is reverse proxied via IIS - you can see my config in this topic - Subfolder install - external links get changed/redirected to site relative links
If I access http://localhost/sidekiq in the container I get the standard this page is private or doesn’t exist response. If I try http://www.finalbuilder.com/forums/sidekiq I just get ‘Forbiddden’. Not sure about the non standard port, haven’t seen that mentioned anywhere with regards to subfolder installs. I get the feeling this is an issue with the proxy not passing enough info for sidekiq to authenticate.
I’m going to have a go at setting up a dev environment over the next few days and see if I can figure out what is going on, but not being a ruby dev (mostly c# and typescript) I’m not sure how far I will get.
Are you logged in as admin?
Yes, logged in as admin.
I’m seeing something which may or may not be related.
As mentioned, this is a subfolder install,using SSO (which goes to the main site).
After logging in I see these cookies
  • _t path=“/”
  • _forum_session path=“/forums”
if I the navigate (logged in as an admin) to “/forums/sidekiq” (returns the text Forbidden and a 403 result)
I get extra cookies :
  • _forum_session path=“/”
  • rack.session path=“/”
Looking at the code, _forum_session cookie creation does take the relative path into account
So how am I ended up with another session with the root path? Anyway, putting this up here in case it proves useful info for someone. Still trying to figure out why I can’t access the sidekiq web interface (the intention being to see if there was any info on why the lightbox stuff isn’t working).
Ok, got past the Sidekiq issue, I found this in the unicorn.stderr.log
WARN -- : attack prevented by Rack::Protection::IPSpoofing
which lead me to look at the IPSpoofing source code and figured out the problem was the HTTP_X_REAL_IP header I was forwarding… removed it and now I an access sidekiq.
Sidekiq appears to be running normally, but lightbox is still not working. Any other suggestions on where to look?
Edit (since I can’t post more than 3 consecutive replies!) :
Problem solved. I found the same error as this case
in our production logs, and he mentioned dns. DNS appeared to be working, however I had it as 1.1.1.1, 8.8.8.8 on the host, I changed that around to 8.8.8.8, 8.8.4.4, 1.1.1.1 and rebooted the host (restarting the container didn’t seem to help).
I have no idea why this change worked, as I could curl the image url in the container just fine, and dns appeared to be working.
1 me gusta
