Using Browserstack I can browse for a file, but it hangs on processing.
There is an Uppy error in console.
I checked the exact same functionality on meta.discourse.org to exclude any theming we have on our install.
But this would not even open the file dialog.
Is it the case that Safari 13 is no longer supported?
thanks
Falco
(Falco)
22 בדצמבר, 2021, 4:02pm
We are using Blob.ArrayBuffer() web API to generate checksums client side for uploads now. That is indeed Safari 14 onwards.
We already have a skip here for IE11 @martin , can we do the same for old Safari?
If skipping is safe, I have this to do it:
https://github.com/discourse/discourse/pull/15391
4 לייקים
martin
(Martin Brennan)
22 בדצמבר, 2021, 10:16pm
3
Yes I think that is fine, thanks for the fix, will approve + merge
2 לייקים
brilliant, thank you both for the speedy response!
2 לייקים
Falco
(Falco)
נסגר ב־
27 בדצמבר, 2021, 11:00am
5
This topic was automatically closed after 3 days. New replies are no longer allowed.
