Image zoom is not working
It does not always work to increase the modal window
I do not know how to replicate the bug but it is
I tested on all browsers
I have lost features such as zoom in images
Just I figured out the reason
this plugin breaks pictures and video
it needs to be fixed!
2 лайка
Hi, I’d just like to point out that a human (namely @tgxworld) wrote that plugin without being paid for it, and provided it to you free of charge because he’s a nice guy who wants Discourse to be cooler. (He works for Discourse now, but I don’t think he did when this code was written, and either way this is not an officially supported plugin.)
So, while it’s great to report this issue, no one actually owes you a fix, and demanding one in big bold letters does not help matters. I’m sure @tgxworld or someone will be happy to fix it as their time allows.
15 лайков
Yeah I think there is some confusion here. The plugin you have diagnosed as root cause is not an official Discourse plugin, therefore you are best reaching out to that plugin author.
Might I also suggest that in doing so, you reconsider your approach. Honey works better than vinegar.
2 лайка
Translator is official though so this should be fixed @tgxworld
5 лайков
I sit corrected. Carry-on
1 лайк
Did you remove/disable the plugin in order for the issue to resolve? Anything in /logs?
I have the plugin enabled on my dev instance and I’m not getting an error.
I can’t replicate the bug as well so unless you can provide exact reproduction steps for the error you’re seeing, it is going to be hard for me to figure out where the bug is.
2 лайка
Refresh the page after translation
I updated the plugin
Error remained
If you do not have an error, try to connect this plug-in yet
Perhaps the error occurs because of two plug-ins, at the moment I have only two of their
Ok the bug isn’t with discourse-translator but the plugin happens to trigger the bug.
To replica, run the following commands. Somehow saving a post with an img wrapped in lightbox will remove the lightbox even though the Post#raw hasn’t been changed.
[2] pry(main)> post = Post.last
[3] pry(main)> post.cooked
=> "<p><div class=\"lightbox-wrapper\"><a data-download-href=\"//localhost:3000/uploads/default/34784374092783e2fef84b8bc96d9b54c11ceea0\" href=\"//localhost:3000/uploads/default/original/1X/34784374092783e2fef84b8bc96d9b54c11ceea0.gif\" class=\"lightbox\" title=\"Sword reworks.gif\"><img src=\"//localhost:3000/uploads/default/optimized/1X/34784374092783e2fef84b8bc96d9b54c11ceea0_1_690x276.gif\" width=\"690\" height=\"276\"><div class=\"meta\">\n<span class=\"filename\">Sword reworks.gif</span><span class=\"informations\">1000x400 1000 KB</span><span class=\"expand\"></span>\n</div></a></div></p>\n\n<p>This is a test post</p>"
[4] pry(main)> post.save!
   (0.2ms)  BEGIN
  User Load (0.3ms)  SELECT  "users".* FROM "users" WHERE "users"."id" = 1 LIMIT 1  [["id", 1]]
  Topic Load (0.5ms)  SELECT  "topics".* FROM "topics" WHERE ("topics"."deleted_at" IS NULL) AND "topics"."id" = 11 LIMIT 1  [["id", 11]]
  SQL (0.3ms)  UPDATE "posts" SET "cooked" = '<p><img src="/uploads/default/original/1X/34784374092783e2fef84b8bc96d9b54c11ceea0.gif" width="690" height="276"></p>
<p>This is a test post</p>', "baked_at" = '2016-10-23 16:51:22.486791', "updated_at" = '2016-10-23 16:51:22.487000' WHERE "posts"."id" = 28  [["cooked", "<p><img src=\"/uploads/default/original/1X/34784374092783e2fef84b8bc96d9b54c11ceea0.gif\" width=\"690\" height=\"276\"></p>\n\n<p>This is a test post</p>"], ["baked_at", Sun, 23 Oct 2016 16:51:22 UTC +00:00], ["updated_at", Sun, 23 Oct 2016 16:51:22 UTC +00:00], ["id", 28]]
   (0.1ms)  SAVEPOINT active_record_1
  UserAction Load (0.3ms)  SELECT  "user_actions".* FROM "user_actions" WHERE "user_actions"."action_type" = 5 AND "user_actions"."user_id" = 1 AND "user_actions"."acting_user_id" = 1 AND "user_actions"."target_post_id" = 28 AND "user_actions"."target_topic_id" = 11 LIMIT 1  [["action_type", 5], ["user_id", 1], ["acting_user_id", 1], ["target_post_id", 28], ["target_topic_id", 11]]
   (0.1ms)  RELEASE SAVEPOINT active_record_1
  Category Load (0.3ms)  SELECT  "categories".* FROM "categories" WHERE "categories"."id" = 1 LIMIT 1  [["id", 1]]
   (2.5ms)  COMMIT
=> true
[5] pry(main)> post.cooked
=> "<p><img src=\"/uploads/default/original/1X/34784374092783e2fef84b8bc96d9b54c11ceea0.gif\" width=\"690\" height=\"276\"></p>\n\n<p>This is a test post</p>"
3 лайка
I do not quite understand this means I need to do something, or what?
Is the data-download-href a URI but not a URL ?
vs.
1 лайк
PR in
https://github.com/discourse/discourse/pull/4513
7 лайков
