iOS Mail アプリのメール本文から AWS の画像が表示されない
I don’t know where that code is, but we’re looking at the topic’s preview image (t.image_url) and rendering it using url_for_email(t.image_url) like so:
Maybe iPhone Mail doesn’t like <img src="//somewhere.com/image.png">? Also I don’t see where that “baseballcap” text could be coming from…
I think that’s the issue too
I’m guessing the URL to the image you use is held in t.image_url ?
I know the language I use here is wrong, but you’ll understand my logic :slight_smile:
Could someone add a simple:
IF LEFT(t.image_url, 6) =! 'https:' THEN t.image_url = 'https:' & t.image_url
:thinking:
And re:
That’ll be coming from here:
Please let me know if I can provide any more details? :+1:t2:
Why not simply change all your CDN urls to be https:// vs // and then rebake everything.
I don’t have any CDNs, @sam? :thinking:
I recommend adding one then, it will save you money anyway
That seems a bit excessive when simply adding 6 characters to the URL (https:) could fix this issue for everyone :confused:
You can set the CDN url to your s3 base url and add the https there, it should work
