Implémenter le bouton de déconnexion
Hi,
I want to implement a logout button outside Discourse. The button should have same functionality like -
  1. It should logout users from all device
  2. A referesh button which will take user to some url.
Note: Login button will be in discourse, but logout option will be outside.
Any article/dicussion/help will be highly appreciated.
Thank you
You can log users out through the Discourse API by making an authenticated POST request to /admin/users/<user_id>/log_out. You need to replace <user_id> with the user’s Discourse user ID.
You can see this implemented in the Discourse WordPress plugin here: wp-discourse/lib/sso-provider/discourse-sso.php at main · discourse/wp-discourse · GitHub
Hi @simon , i will need to enable sso for this functionality. right? and if yes what are the things i will need to fill/enable for enabling sso just for logout?
No, enabling SSO is not required for the call to /admin/users/<user_id>/log_out to work.
I am getting 404 error. can you help me?
You need to set both the Api-Key and Api-Username headers. If you are using the All Users API Key, the Api-Username header should probably be set to ‘system’
Thank you. It worked.
