Import from phpbb, using S3 storage
I’ve run an import from a reasonably large (~150k posts) phpBB forum, and enabled S3 uploads before doing this. However, none of the images/attachments are working. They seem to have appeared in the S3 bucket, but they’re under the “tombstone” folder, rather than the “original” folder.
I wonder if this is because I hadn’t enabled public read access to the S3 bucket during the import.
Is there a rake task, or similar, which I can run to fix the files, or do I need to delete everything and run the importer again for another 6 hours?
How are they referenced (ie. what URL is used) in the posts?
