Import_scripts mancanti
Hello,
I want to try to import my old bbpress forum to my discourse, I hope it will be good :slight_smile:
But the import_scripts directory is missing. How can I install it?
I want to use this:
thank you
(I’m completely new in discourse)
The folder isn’t missing, you’re just looking for it outside Docker.
From within the app the path is:
/var/www/discourse/script/import_scripts
Are you doing the import on a development install, or trying to migrate from within Discourse built using the cloud install guide?
It’s all explained in the first paragraph of the guide:
Before starting the migration set a development environment on your machine (or inside a virtual machine) and run the import there instead of inside the docker container.
You can have a look at my little howto:
Thank you, I found it! :slight_smile:
