ייבוא / העברה מ-Zendesk Community ל-Discourse
סיכום מבוסס בינה מלאכותית
johnsnowtesting123 is trying to migrate content from Zendesk Community to Discourse using the import script discourse/import_scripts/zendesk.rb. However, when running the script, they’re encountering errors due to missing gems (nokogiri, mini_portile2, libv8-node), despite them being installed according to the gemfile.lock. They’ve provided their setup details, including their Discourse development instance setup, macOS version, and Ruby version, in hopes of resolving the issue.
Hello Discourse Community, I am looking to use the Discourse forum but want to migrate content from Zendesk Community using the import script discourse/import_scripts/zendesk.rb
I have 4 CSV files inn the import_scripts folder (comments.csv, users.csv, topics.csv, posts.csv), but when I try to run the script using the following commands:
RAILS_ENV=production IMPORT=1 bundle install
RAILS_ENV=production bundle exec ruby script/import_scripts/zendesk.rb ./script/import_scripts/
it leads to these errors:
Could not find nokogiri-1.13.3, mini_portile2-2.8.0, libv8-node-16.10.0.0 in any of the sources
Run `bundle install` to install missing gems.
Checking gemfile.lock, it seems that nokogiri, mini_portile2, libv8-node, were installed.
nokogiri -v results in the following:
# Nokogiri (1.13.3)
    warnings: []
    nokogiri:
      version: 1.13.3
      cppflags:
      - "-I/Users/g001494/.rbenv/versions/2.7.3/lib/ruby/gems/2.7.0/gems/nokogiri-1.13.3-x86_64-darwin/ext/nokogiri"
      - "-I/Users/g001494/.rbenv/versions/2.7.3/lib/ruby/gems/2.7.0/gems/nokogiri-1.13.3-x86_64-darwin/ext/nokogiri/include"
      - "-I/Users/g001494/.rbenv/versions/2.7.3/lib/ruby/gems/2.7.0/gems/nokogiri-1.13.3-x86_64-darwin/ext/nokogiri/include/libxml2"
      ldflags: []
    ruby:
      version: 2.7.3
      platform: x86_64-darwin21
      gem_platform: x86_64-darwin-21
      description: ruby 2.7.3p183 (2021-04-05 revision 6847ee089d) [x86_64-darwin21]
      engine: ruby
    libxml:
      source: packaged
      precompiled: true
      patches:
      - 0001-Remove-script-macro-support.patch
      - 0002-Update-entities-to-remove-handling-of-ssi.patch
      - 0003-libxml2.la-is-in-top_builddir.patch
      - 0004-use-glibc-strlen.patch
      - 0005-avoid-isnan-isinf.patch
      - 0006-update-automake-files-for-arm64.patch
      - '0008-htmlParseComment-handle-abruptly-closed-comments.patch'
      - '0009-allow-wildcard-namespaces.patch'
      - 0010-Revert-Different-approach-to-fix-quadratic-behavior.patch
      libxml2_path: "/Users/g001494/.rbenv/versions/2.7.3/lib/ruby/gems/2.7.0/gems/nokogiri-1.13.3-x86_64-darwin/ext/nokogiri"
      memory_management: ruby
      iconv_enabled: true
      compiled: 2.9.13
      loaded: 2.9.13
    libxslt:
      source: packaged
      precompiled: true
      patches:
      - 0001-update-automake-files-for-arm64.patch
      datetime_enabled: true
      compiled: 1.1.35
      loaded: 1.1.35
    other_libraries:
      zlib: 1.2.11
      libiconv: '1.16'
      libgumbo: 1.0.0-nokogiri
Specs:
2 לייקים
