שיפורים לזמני בניית js בסביבות דלות זיכרון (מאי 2024)
סיכום מבוסס בינה מלאכותית
The post discusses improvements made to Discourse’s JavaScript build tooling to significantly reduce rebuild times on low-memory servers (1GB RAM + 2GB). david mentions a commit that reduces the ember build portion from around 45 minutes to 15 minutes on a DigitalOcean 1GB droplet.
merefield praises this as an excellent commitment to the self-hosted community, helping keep costs down and driving adoption. pfaffman confirms the improvements, noting a full test install including droplet creation, DNS setup, SMTP configuration, and rebuilding with plugins took only 23 minutes on a 1GB drop, reviving the “30 Minute Install” possibility.
Overall, the changes optimize Discourse’s build process for low-memory environments, benefiting self-hosters and making it more accessible to set up on modest hardware.
Our official install guide lists 1GB of RAM (+2GB swap) as the minimum requirements for Discourse. This is still possible, but over the last few months it has become increasingly painful to rebuild Discourse with servers of this spec. This is primarily because of changes to our JS build tooling.
We’ve just landed these tweaks, which should significantly improve rebuild times on low-memory servers:
https://github.com/discourse/discourse/commit/9db5eafb15688cf0604805fb5b315efca1c712a6
Given the number of variables it’s hard to promise exact numbers. But, in my tests on a DO droplet with 1GB RAM (+2GB swap), this reduced the ember build portion of a ./launcher rebuild app from ~45 minutes to ~15 minutes.
There may also be a slight speed improvement for machines with more RAM, but nothing too substantial.
If you run Discourse on a low-memory machine, please give it a try and let us know how you get on!
I’m sure I’m not alone here in this thinking, but this will really help self-hosters and keep their costs down, driving adoption, super!!
An excellent show of commitment to the community, thank you!
Nice!
I just did a test install and the whole thing, including droplet creation, (automatic) DNS configuration, getting SMTP credentials from Mailgun, and the rebuild with a bunch of plugins (plus deleting the droplet) took just 23 minutes. This is awesome, as I’d been running this test on an 8GB droplet because the 1GB was taking so darn long.
It looks like the 30 Minute Install is possible once again!
