У меня установлены оба этих плагина.
URL-адрес для просмотра юбилеев (/cakeday/anniversaries/today) выдаёт следующую ошибку:
Полные логи:
activemodel (7.0.3.1) lib/active_model/attribute.rb:226:in `value'
activemodel (7.0.3.1) lib/active_model/attribute_set/builder.rb:55:in `block in fetch_value'
activemodel (7.0.3.1) lib/active_model/attribute_set/builder.rb:46:in `fetch'
activemodel (7.0.3.1) lib/active_model/attribute_set/builder.rb:46:in `fetch_value'
activerecord (7.0.3.1) lib/active_record/attribute_methods/read.rb:38:in `_read_attribute'
activemodel (7.0.3.1) lib/active_model/attribute_methods.rb:277:in `admin'
app/models/concerns/roleable.rb:14:in `staff?'
plugins/discourse-animated-avatars/plugin.rb:90:in `block (2 levels) in activate!'
lib/plugin/instance.rb:285:in `public_send'
lib/plugin/instance.rb:285:in `block (2 levels) in add_to_class'
activesupport (7.0.3.1) lib/active_support/core_ext/object/try.rb:15:in `public_send'
activesupport (7.0.3.1) lib/active_support/core_ext/object/try.rb:15:in `try'
plugins/discourse-animated-avatars/plugin.rb:94:in `block (2 levels) in activate!'
(eval):7:in `_fast_attributes'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:468:in `rescue in attributes'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:455:in `attributes'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:480:in `_serializable_hash'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:359:in `serializable_hash'
active_model_serializers (0.8.4) lib/active_model/array_serializer.rb:89:in `block in _serializable_array'
active_model_serializers (0.8.4) lib/active_model/array_serializer.rb:79:in `map'
active_model_serializers (0.8.4) lib/active_model/array_serializer.rb:79:in `_serializable_array'
active_model_serializers (0.8.4) lib/active_model/array_serializer.rb:73:in `serializable_array'
active_model_serializers (0.8.4) lib/active_model/array_serializer.rb:53:in `as_json'
app/controllers/application_controller.rb:519:in `serialize_data'
plugins/discourse-cakeday/app/controllers/discourse_cakeday/anniversaries_controller.rb:53:in `index'
actionpack (7.0.3.1) lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack (7.0.3.1) lib/abstract_controller/base.rb:215:in `process_action'
actionpack (7.0.3.1) lib/action_controller/metal/rendering.rb:53:in `process_action'
actionpack (7.0.3.1) lib/abstract_controller/callbacks.rb:234:in `block in process_action'
activesupport (7.0.3.1) lib/active_support/callbacks.rb:118:in `block in run_callbacks'
app/controllers/application_controller.rb:413:in `block in with_resolved_locale'
i18n (1.12.0) lib/i18n.rb:322:in `with_locale'
app/controllers/application_controller.rb:413:in `with_resolved_locale'
activesupport (7.0.3.1) lib/active_support/callbacks.rb:127:in `block in run_callbacks'
activesupport (7.0.3.1) lib/active_support/callbacks.rb:138:in `run_callbacks'
actionpack (7.0.3.1) lib/abstract_controller/callbacks.rb:233:in `process_action'
actionpack (7.0.3.1) lib/action_controller/metal/rescue.rb:22:in `process_action'
actionpack (7.0.3.1) lib/action_controller/metal/instrumentation.rb:67:in `block in process_action'
activesupport (7.0.3.1) lib/active_support/notifications.rb:206:in `block in instrument'
activesupport (7.0.3.1) lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport (7.0.3.1) lib/active_support/notifications.rb:206:in `instrument'
actionpack (7.0.3.1) lib/action_controller/metal/instrumentation.rb:66:in `process_action'
actionpack (7.0.3.1) lib/action_controller/metal/params_wrapper.rb:259:in `process_action'
activerecord (7.0.3.1) lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack (7.0.3.1) lib/abstract_controller/base.rb:151:in `process'
actionview (7.0.3.1) lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler (3.0.0) lib/mini_profiler/profiling_methods.rb:111:in `block in profile_method'
actionpack (7.0.3.1) lib/action_controller/metal.rb:188:in `dispatch'
actionpack (7.0.3.1) lib/action_controller/metal.rb:251:in `dispatch'
actionpack (7.0.3.1) lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
actionpack (7.0.3.1) lib/action_dispatch/routing/route_set.rb:32:in `serve'
actionpack (7.0.3.1) lib/action_dispatch/journey/router.rb:50:in `block in serve'
actionpack (7.0.3.1) lib/action_dispatch/journey/router.rb:32:in `each'
actionpack (7.0.3.1) lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack (7.0.3.1) lib/action_dispatch/routing/route_set.rb:852:in `call'
railties (7.0.3.1) lib/rails/engine.rb:530:in `call'
railties (7.0.3.1) lib/rails/railtie.rb:226:in `public_send'
railties (7.0.3.1) lib/rails/railtie.rb:226:in `method_missing'
actionpack (7.0.3.1) lib/action_dispatch/routing/mapper.rb:19:in `block in <class:Constraints>'
actionpack (7.0.3.1) lib/action_dispatch/routing/mapper.rb:48:in `serve'
lib/middleware/omniauth_bypass_middleware.rb:71:in `call'
rack (2.2.4) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.4) lib/rack/conditional_get.rb:27:in `call'
rack (2.2.4) lib/rack/head.rb:12:in `call'
actionpack (7.0.3.1) lib/action_dispatch/http/permissions_policy.rb:38:in `call'
rack (2.2.4) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.4) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (7.0.3.1) lib/action_dispatch/middleware/cookies.rb:697:in `call'
activerecord (7.0.3.1) lib/active_record/migration.rb:603:in `call'
actionpack (7.0.3.1) lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
activesupport (7.0.3.1) lib/active_support/callbacks.rb:99:in `run_callbacks'
actionpack (7.0.3.1) lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack (7.0.3.1) lib/action_dispatch/middleware/executor.rb:14:in `call'
actionpack (7.0.3.1) lib/action_dispatch/middleware/actionable_exceptions.rb:17:in `call'
actionpack (7.0.3.1) lib/action_dispatch/middleware/debug_exceptions.rb:28:in `call'
actionpack (7.0.3.1) lib/action_dispatch/middleware/show_exceptions.rb:26:in `call'
logster (2.11.3) lib/logster/middleware/reporter.rb:43:in `call'
railties (7.0.3.1) lib/rails/rack/logger.rb:40:in `call_app'
railties (7.0.3.1) lib/rails/rack/logger.rb:27:in `call'
config/initializers/100-quiet_logger.rb:23:in `call'
config/initializers/100-silence_logger.rb:31:in `call'
actionpack (7.0.3.1) lib/action_dispatch/middleware/remote_ip.rb:93:in `call'
actionpack (7.0.3.1) lib/action_dispatch/middleware/request_id.rb:26:in `call'
rack (2.2.4) lib/rack/method_override.rb:24:in `call'
actionpack (7.0.3.1) lib/action_dispatch/middleware/static.rb:23:in `call'
rack (2.2.4) lib/rack/sendfile.rb:110:in `call'
actionpack (7.0.3.1) lib/action_dispatch/middleware/host_authorization.rb:137:in `call'
lib/middleware/missing_avatars.rb:23:in `call'
lib/middleware/turbo_dev.rb:34:in `call'
rack-mini-profiler (3.0.0) lib/mini_profiler/profiler.rb:393:in `call'
message_bus (4.3.0) lib/message_bus/rack/middleware.rb:60:in `call'
rack (2.2.4) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.4) lib/rack/urlmap.rb:58:in `each'
rack (2.2.4) lib/rack/urlmap.rb:58:in `call'
unicorn (6.1.0) lib/unicorn/http_server.rb:634:in `process_client'
unicorn (6.1.0) lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn (6.1.0) lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn (6.1.0) lib/unicorn/http_server.rb:143:in `start'
unicorn (6.1.0) bin/unicorn:128:in `<top (required)>'
bin/unicorn:96:in `load'
bin/unicorn:96:in `block in <main>'
bin/unicorn:95:in `fork'
bin/unicorn:95:in `<main>'
Я попытался разобраться в точной причине этой проблемы. На мой взгляд, наиболее релевантные строки здесь:
Похоже, что проблема заключается в том, что при вызове функции «staff?» она отсутствует у объекта пользователя, на который здесь ссылаются, из-за чего в плагине Animated Avatar возникает ошибка:
Это восходит к плагину Cakeday, когда происходит сериализация списка пользователей:
Теперь, я не эксперт в том, как именно работает сериализация здесь, но если бы мне пришлось дать приблизительный диагноз, то это выглядело бы так: плагину Animated Avatar передаётся объект «user», у которого отсутствуют некоторые ожидаемые свойства объекта пользователя, а именно функция staff? (а также trust_level, что я выяснил). Думаю, воспроизвести эту ошибку может быть немного сложно, так как для этого необходимо, чтобы на странице /cakeday/anniversaries/today отображались пользователи, что было нетривиально добиться на моём экземпляре разработки.
На моём рабочем форуме я также подтвердил, что эта проблема сохраняется в безопасном режиме (только официальные плагины).
Аналогичная проблема сообщается здесь: Discourse Cakeday - #200
