Enlace incorrecto en la clave de respuesta por correo electrónico al usar subcarpeta
Hey Guys,
I found another issue with the subfolder install: when looking at sent emails I can’t open the reply key links in a new tab (cmd+click) because the href doesn’t include the subfolder.
Clicking them does work, I assume the ember routing it doing its magic there. Attached screenshot shows the issue, I’m hovering the reply key link to show you the href in the status bar:
Not critical but might be an easy fix or allow you to rethink your subfolder approach in the frontend.
Cheers!
5 Me gusta
Sure looks like legit minor subfolder bug cc @neil
It is fixed as per commit
5 Me gusta
This topic was automatically closed after 24 hours. New replies are no longer allowed.
