Hello!
I wanted to post on here to see if anyone had ideas about this bug I am seeing when trying to use Sentry with discourse. I am looking to use Sentry (using the open source Glitchtip server implementation ) to collect all errors raised in background tasks and in the server. I know that discourse has its own error collection with Logster, but I wanted to try using Sentry to help track all the errors that are raised and inspect them with more context.
I added an initializer with the Sentry config:
Sentry.init do |config|
config.breadcrumbs_logger = [:active_support_logger, :http_logger]
config.dsn = ENV['SENTRY_DSN']
and was finding that it was infinitely recursing during HTTP calls of the rake tasks and sidekiq tasks (even if they would exit cleanly before sentry was added). There are more details and a way to reproduce on the Github issue I opened with sentry-ruby:
opened 09:40PM - 06 Feb 23 UTC
closed 06:32PM - 13 Feb 23 UTC
sentry-ruby
Bug
### Issue Description
Hello!
I am coming across an error trying to use the… sentry ruby bindings on with a rails app, during a rake task. The task uploads the precompiled assets to an S3 server. It exits cleanly without the sentry integration, but when I add it, it enters into an infinitely recursive loop with the patched HTTP module. I am not sure how to debug this further or what to do.
Thank you!
### Reproduction Steps
**edited with simpler steps**:
```bash
$ git clone https://github.com/saulshanabrook/discourse-hosting
$ cd discourse-hosting
$ echo 'HOSTNAME=any-domain.com' > .env
$ docker compose run --rm upload_assets
Following the steps of https://github.com/saulshanabrook/discourse-hosting#local-development-with-docker-compose the error will be raised when running `docker compose run --rm upload_assets`:
### Expected Behavior
The command exits cleanly without an error
### Actual Behavior
It raises a `SystemStackError`:
```ruby
[+] Running 4/0
⠿ Container discourse-hosting-db-1 Running 0.0s
⠿ Container discourse-hosting-minio-1 Running 0.0s
⠿ Container discourse-hosting-redis-1 Running 0.0s
⠿ Container discourse-hosting-glitchtip-web-1 Running 0.0s
** Invoke s3:upload_assets (first_time)
** Invoke environment (first_time)
** Execute environment
** Invoke s3:ensure_cors_rules (first_time)
** Execute s3:ensure_cors_rules
** Execute s3:upload_assets
rake aborted!
SystemStackError: stack level too deep
/usr/local/bundle/gems/sentry-ruby-5.8.0/lib/sentry/net/http.rb:35:in `block in request'
/usr/local/bundle/gems/sentry-ruby-5.8.0/lib/sentry/hub.rb:100:in `with_child_span'
/usr/local/bundle/gems/sentry-ruby-5.8.0/lib/sentry-ruby.rb:446:in `with_child_span'
/usr/local/bundle/gems/sentry-ruby-5.8.0/lib/sentry/net/http.rb:32:in `request'
(eval):5:in `request'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/seahorse/client/net_http/connection_pool.rb:348:in `request'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/seahorse/client/net_http/handler.rb:79:in `block in transmit'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/seahorse/client/net_http/handler.rb:133:in `block in session'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/seahorse/client/net_http/connection_pool.rb:104:in `session_for'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/seahorse/client/net_http/handler.rb:128:in `session'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/seahorse/client/net_http/handler.rb:76:in `transmit'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/seahorse/client/net_http/handler.rb:50:in `call'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/seahorse/client/plugins/content_length.rb:24:in `call'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/seahorse/client/plugins/request_callback.rb:85:in `call'
/usr/local/bundle/gems/aws-sdk-s3-1.114.0/lib/aws-sdk-s3/plugins/s3_signer.rb:132:in `call'
/usr/local/bundle/gems/aws-sdk-s3-1.114.0/lib/aws-sdk-s3/plugins/s3_signer.rb:63:in `call'
/usr/local/bundle/gems/aws-sdk-s3-1.114.0/lib/aws-sdk-s3/plugins/s3_host_id.rb:17:in `call'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/xml/error_handler.rb:10:in `call'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/plugins/transfer_encoding.rb:26:in `call'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/plugins/helpful_socket_errors.rb:12:in `call'
/usr/local/bundle/gems/aws-sdk-s3-1.114.0/lib/aws-sdk-s3/plugins/s3_signer.rb:110:in `call'
/usr/local/bundle/gems/aws-sdk-s3-1.114.0/lib/aws-sdk-s3/plugins/redirects.rb:20:in `call'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/plugins/retry_errors.rb:360:in `call'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/plugins/http_checksum.rb:19:in `call'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/plugins/endpoint_pattern.rb:30:in `call'
/usr/local/bundle/gems/aws-sdk-s3-1.114.0/lib/aws-sdk-s3/plugins/accelerate.rb:67:in `call'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/plugins/checksum_algorithm.rb:136:in `call'
/usr/local/bundle/gems/aws-sdk-s3-1.114.0/lib/aws-sdk-s3/plugins/bucket_dns.rb:35:in `call'
/usr/local/bundle/gems/aws-sdk-s3-1.114.0/lib/aws-sdk-s3/plugins/dualstack.rb:41:in `call'
/usr/local/bundle/gems/aws-sdk-s3-1.114.0/lib/aws-sdk-s3/plugins/expect_100_continue.rb:22:in `call'
/usr/local/bundle/gems/aws-sdk-s3-1.114.0/lib/aws-sdk-s3/plugins/bucket_name_restrictions.rb:26:in `call'
/usr/local/bundle/gems/aws-sdk-s3-1.114.0/lib/aws-sdk-s3/plugins/arn.rb:62:in `call'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/rest/handler.rb:10:in `call'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/plugins/recursion_detection.rb:18:in `call'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/plugins/user_agent.rb:13:in `call'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/seahorse/client/plugins/endpoint.rb:47:in `call'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/plugins/param_validator.rb:26:in `call'
/usr/local/bundle/gems/aws-sdk-s3-1.114.0/lib/aws-sdk-s3/plugins/arn.rb:88:in `call'
/usr/local/bundle/gems/aws-sdk-s3-1.114.0/lib/aws-sdk-s3/plugins/sse_cpk.rb:24:in `call'
/usr/local/bundle/gems/aws-sdk-s3-1.114.0/lib/aws-sdk-s3/plugins/dualstack.rb:27:in `call'
/usr/local/bundle/gems/aws-sdk-s3-1.114.0/lib/aws-sdk-s3/plugins/accelerate.rb:56:in `call'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/plugins/checksum_algorithm.rb:111:in `call'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/plugins/jsonvalue_converter.rb:22:in `call'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/plugins/idempotency_token.rb:19:in `call'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/plugins/param_converter.rb:26:in `call'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/seahorse/client/plugins/request_callback.rb:71:in `call'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/plugins/response_paging.rb:12:in `call'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/seahorse/client/plugins/response_target.rb:24:in `call'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/seahorse/client/request.rb:72:in `send_request'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/waiters/poller.rb:65:in `send_request'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/waiters/poller.rb:51:in `call'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/waiters/waiter.rb:107:in `block in poll'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/waiters/waiter.rb:104:in `loop'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/waiters/waiter.rb:104:in `poll'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/waiters/waiter.rb:94:in `block (2 levels) in wait'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/waiters/waiter.rb:93:in `catch'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/waiters/waiter.rb:93:in `block in wait'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/waiters/waiter.rb:92:in `catch'
/usr/local/bundle/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/waiters/waiter.rb:92:in `wait'
/usr/local/bundle/gems/aws-sdk-s3-1.114.0/lib/aws-sdk-s3/waiters.rb:123:in `wait'
/usr/local/bundle/gems/aws-sdk-s3-1.114.0/lib/aws-sdk-s3/bucket.rb:98:in `wait_until_exists'
/usr/local/bundle/gems/aws-sdk-s3-1.114.0/lib/aws-sdk-s3/bucket.rb:79:in `exists?'
/var/www/discourse/lib/s3_helper.rb:404:in `s3_bucket'
/var/www/discourse/lib/s3_helper.rb:240:in `list'
/var/www/discourse/lib/tasks/s3.rake:14:in `existing_assets'
/var/www/discourse/lib/tasks/s3.rake:24:in `should_skip?'
/var/www/discourse/lib/tasks/s3.rake:36:in `upload'
/var/www/discourse/lib/tasks/s3.rake:192:in `block (2 levels) in <main>'
/var/www/discourse/lib/tasks/s3.rake:192:in `each'
/var/www/discourse/lib/tasks/s3.rake:192:in `block in <main>'
/usr/local/lib/ruby/gems/3.1.0/gems/rake-13.0.6/lib/rake/task.rb:281:in `block in execute'
/usr/local/lib/ruby/gems/3.1.0/gems/rake-13.0.6/lib/rake/task.rb:281:in `each'
/usr/local/lib/ruby/gems/3.1.0/gems/rake-13.0.6/lib/rake/task.rb:281:in `execute'
/usr/local/bundle/gems/sentry-ruby-5.8.0/lib/sentry/rake.rb:26:in `execute'
/usr/local/lib/ruby/gems/3.1.0/gems/rake-13.0.6/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
/usr/local/lib/ruby/gems/3.1.0/gems/rake-13.0.6/lib/rake/task.rb:199:in `synchronize'
/usr/local/lib/ruby/gems/3.1.0/gems/rake-13.0.6/lib/rake/task.rb:199:in `invoke_with_call_chain'
/usr/local/lib/ruby/gems/3.1.0/gems/rake-13.0.6/lib/rake/task.rb:188:in `invoke'
/usr/local/lib/ruby/gems/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:160:in `invoke_task'
/usr/local/lib/ruby/gems/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:116:in `block (2 levels) in top_level'
/usr/local/lib/ruby/gems/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:116:in `each'
/usr/local/lib/ruby/gems/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:116:in `block in top_level'
/usr/local/lib/ruby/gems/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:125:in `run_with_threads'
/usr/local/lib/ruby/gems/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:110:in `top_level'
/usr/local/lib/ruby/gems/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:83:in `block in run'
/usr/local/lib/ruby/gems/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:186:in `standard_exception_handling'
/usr/local/lib/ruby/gems/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:80:in `run'
/usr/local/lib/ruby/gems/3.1.0/gems/rake-13.0.6/exe/rake:27:in `<top (required)>'
/usr/local/bin/rake:25:in `load'
/usr/local/bin/rake:25:in `<top (required)>'
/usr/local/bundle/gems/bundler-2.3.22/lib/bundler/cli/exec.rb:58:in `load'
/usr/local/bundle/gems/bundler-2.3.22/lib/bundler/cli/exec.rb:58:in `kernel_load'
/usr/local/bundle/gems/bundler-2.3.22/lib/bundler/cli/exec.rb:23:in `run'
/usr/local/bundle/gems/bundler-2.3.22/lib/bundler/cli.rb:486:in `exec'
/usr/local/bundle/gems/bundler-2.3.22/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/usr/local/bundle/gems/bundler-2.3.22/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/usr/local/bundle/gems/bundler-2.3.22/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
/usr/local/bundle/gems/bundler-2.3.22/lib/bundler/cli.rb:31:in `dispatch'
/usr/local/bundle/gems/bundler-2.3.22/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
/usr/local/bundle/gems/bundler-2.3.22/lib/bundler/cli.rb:25:in `start'
/usr/local/bundle/gems/bundler-2.3.22/exe/bundle:48:in `block in <top (required)>'
/usr/local/bundle/gems/bundler-2.3.22/lib/bundler/friendly_errors.rb:120:in `with_friendly_errors'
/usr/local/bundle/gems/bundler-2.3.22/exe/bundle:36:in `<top (required)>'
/usr/local/bundle/bin/bundle:25:in `load'
/usr/local/bundle/bin/bundle:25:in `<main>'
Tasks: TOP => s3:upload_assets
### Ruby Version
3.1
### SDK Version
sentry-ruby-5.8.0
### Integration and Its Version
_No response_
### Sentry Config
```ruby
# this gem also provides a new breadcrumb logger that accepts instrumentations from ActiveSupport
# it's not activated by default, but you can enable it with
# config.breadcrumbs_logger = [:active_support_logger]
I know that I am not using the supported discourse_docker repo, but I wanted to post here anyway to see if anyone else may have come across a similar error and had any ideas.
Note that there is an existing discourse sentry plugin (Discourse Sentry ), but it uses an unsupported client library (sentry-raven) so I choose not to use it.
For anyone interested in using Sentry with Discourse, one of the maintainers of the package replied with a suggested fix .
They said that the problem was coming from Discourse’s MethodProfiler which uses alias_method . They suggested replacing that with prepend which they said was becoming more common and would allow both tools to work together.
I am not familiar enough with Ruby to understand the differences. For now, I will try commenting out this bit of code to disable Discourse’s method profiling.
