Inject patch in Docker Installation
Hello there,
I’m trying to setup a single sign on system from my custom oauth2 provider.
I found this topic to overwrite the process after successful redirection : https://meta.discourse.org/t/disable-create-account-screen-for-cas-logins/11334/6
I’m using the docker installation, I don’t know how to inject code inside the container, should I bundle this around a plugin and clone it in the after_code hooks ?
Thank you for your help,
Dorian
Yes, you should bundle the necessary functionality into a plugin and install it as part of the container build. You could also change the location that Discourse itself is cloned from to a git repo that contains the patches you want, but forking the main Discourse codebase is just going to leave you with a maintenance headache in the future when you need to update to a newer version of Discourse. So stick with a plugin.
I created a private repository and managed to clone it with mounting my ssh key folder, thank you for your help !
World of pain commencing in 3… 2… 1…
It was pretty easy
  - volume:
      host: /home/server/.ssh
      guest: /root/.ssh
and
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone git@github.com:dorianamouroux/private_repo.git
Ahhhhhhhhhhhhhhhhhh
I guess @mpalmer undestood the same as me. That the private repo was a Discourse fork! It’s a plugin! That’s perfect!
Haha no, just private repository.
But having a private fork of a project is not that complicated, you juste need 2 git remote and you pull the public one when you want updates, I did it for gollum wiki it works like a charm (the project is barely maintained now though)
I had a similar problem, but getting the GitLab oauth to work. I did the following:
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone https://gitlab.com/gitlab-org/discourse-omniauth-gitlab.git
run:
  - exec: apt install unzip
  - exec: unzip /shared/ssl/NTAM_Collection_Ubuntu_2016.2.zip -d /usr/local/share/ca-certificates/
  - exec: chmod 444 /usr/local/share/ca-certificates/*
  - exec: c_rehash /usr/local/share/ca-certificates
  - exec: update-ca-certificates
Sorry I misunderstood what you were saying.
As far as maintaining a private fork of Discourse, here’s the difference:
Discourse has several people employed full-time to add features and fix bugs (including security bugs), as well as a large number of fantastic contributors from all over the Internet. There’s a pretty good chance the changes in a private fork is going to end up conflicting with the changes made in mainline fairly often, necessitating manual review and modification of the local patches.
