מודאל הוספת קישור - ללא תוויות קלט
The “Insert Hyperlink” modal inputs lack labels:
Once you fill it out, you can no longer see which input is what:
In the above example, it’s hard to at a glance check if the inputs are filled in correctly, or if the user entered the values out of order.
The labels are kept in the placeholder property, which is not ideal:
Effective placeholder text includes a word or short phrase that hints at the expected data type, not an explanation or prompt. The placeholder must not be used instead of a <label>
placeholder HTML attribute - HTML | MDN
My proposition is to add labels to each input:
4 לייקים
