Is there a way to add a link to a separate website in an easily accessible location? For example, I want to link my company’s main website somewhere on the home page of the discussion forum. Any tips?
There are a lot of options depending on where you want it:
I’ve seen some sites add a separate home icon with this theme component: Iconified Header Links
Others will add text links: Custom Header Links
If you need an entire header with additional links: Brand header theme component
If you’ve never installed a theme, this will help: How do I install a Theme or Theme Component?
