In a discussion titled ‘Insert text below username?’ under the Dev category and tagged with CSS, DonkeyKongEnjoyer asks how to display custom text beneath usernames site-wide. They initially tried using ::after with CSS but found the text appeared inline. Alteras offered a solution using .names::after with display: block and flex-wrap: wrap, which worked on desktop but rendered above the username on mobile. Alteras later suggested adding order: 4 to fix the mobile layout, which DonkeyKongEnjoyer confirmed worked perfectly. merefield proposed using Group Default Titles as an alternative, allowing per-group customization and styling underneath usernames. Arkshine added that the Discourse API can be used for dynamic content insertion via decorateWidget, with accompanying CSS to adjust layout. This thread provides multiple approaches — pure CSS, group titles, and API-based solutions — to insert text below usernames, with mobile compatibility addressed via flexbox ordering.
