L'installation de Discourse pour le développement avec Docker a échoué
I fail…
Install Discourse for Development using Docker
  • clone Discourse
git clone https://github.com/discourse/discourse.git ~/discourse
  • start dev
cd discourse
./bin/docker/boot_dev --init
./bin/docker/unicorn
open a browser on http://localhost:9777 and I don’t should see Discourse.
why??
(It was changed to 9777 due to port collision.)
Detail :
y@y-VirtualBox:~/discourse$ sudo ./bin/docker/unicorn -x
Running without sidekiq
I, [2019-07-22T17:51:53.863457 #795]  INFO -- : Refreshing Gem list
WARNING: It looks like your discourse plugins have recently changed.
It is highly recommended to remove your `tmp` directory, otherwise
plugins might not work.
Starting CSS change watcher
I, [2019-07-22T17:51:57.024178 #795]  INFO -- : listening on addr=0.0.0.0:9777 fd=13
I, [2019-07-22T17:52:02.327320 #795]  INFO -- : master process ready
I, [2019-07-22T17:52:05.364922 #884]  INFO -- : worker=0 ready
I, [2019-07-22T17:52:05.397963 #894]  INFO -- : worker=1 ready
I, [2019-07-22T17:52:06.423513 #904]  INFO -- : worker=2 ready
Is it running?
Looks like it to me. Have you checked for port 9777 being closed on the dev machine?
docker stop discourse_dev??
I don’t know
Please explain
Please check if port 9777 is properly open.
netstat -nl | grep 9777
Run this command to see if anything is matched.
Originally, the crash occurred at 9292, and it was changed to 9777
