From clean version of Ubuntu 14.04 LTS, here is the error from the install
Success. You can now start the database server using:
/usr/lib/postgresql/9.3/bin/postgres -D /shared/postgres_data
or
/usr/lib/postgresql/9.3/bin/pg_ctl -D /shared/postgres_data -l logfile start
I, [2015-04-06T13:04:51.648386 #45] INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2015-04-06T13:04:51.664015 #45] INFO -- :
I, [2015-04-06T13:04:51.664199 #45] INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2015-04-06T13:04:51.678834 #45] INFO -- :
I, [2015-04-06T13:04:51.679594 #45] INFO -- : > /root/upgrade_postgres
I, [2015-04-06T13:04:51.694165 #45] INFO -- :
I, [2015-04-06T13:04:51.694733 #45] INFO -- : > rm /root/upgrade_postgres
I, [2015-04-06T13:04:51.704441 #45] INFO -- :
I, [2015-04-06T13:04:51.706267 #45] INFO -- : Replacing data_directory = '/var/lib/postgresql/9.3/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/9.3/main/postgresql.conf
I, [2015-04-06T13:04:51.707298 #45] INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/9.3/main/postgresql.conf
I, [2015-04-06T13:04:51.708702 #45] INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/9.3/main/postgresql.conf
I, [2015-04-06T13:04:51.709394 #45] INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/9.3/main/postgresql.conf
I, [2015-04-06T13:04:51.709981 #45] INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/9.3/main/postgresql.conf
I, [2015-04-06T13:04:51.710597 #45] INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/9.3/main/postgresql.conf
I, [2015-04-06T13:04:51.711392 #45] INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2015-04-06T13:04:51.721940 #45] INFO -- :
I, [2015-04-06T13:04:51.722459 #45] INFO -- : Replacing (?-mix:#?max_wal_senders *=.*) with max_wal_senders = 4 in /etc/postgresql/9.3/main/postgresql.conf
I, [2015-04-06T13:04:51.723326 #45] INFO -- : Replacing (?-mix:#?wal_level *=.*) with wal_level = hot_standby in /etc/postgresql/9.3/main/postgresql.conf
I, [2015-04-06T13:04:51.724513 #45] INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres peer in /etc/postgresql/9.3/main/pg_hba.conf
I, [2015-04-06T13:04:51.725340 #45] INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/9.3/main/pg_hba.conf
I, [2015-04-06T13:04:51.726423 #45] INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/9.3/bin/postmaster -D /etc/postgresql/9.3/main
I, [2015-04-06T13:04:51.753588 #45] INFO -- : > sleep 5
2015-04-06 13:04:51 UTC [118-1] LOG: database system was shut down at 2015-04-06 13:04:51 UTC
2015-04-06 13:04:51 UTC [122-1] LOG: autovacuum launcher started
2015-04-06 13:04:51 UTC [115-1] LOG: database system is ready to accept connections
I, [2015-04-06T13:04:56.769954 #45] INFO -- :
I, [2015-04-06T13:04:56.772768 #45] INFO -- : > su postgres -c 'createdb discourse' || true
I, [2015-04-06T13:04:57.097411 #45] INFO -- :
I, [2015-04-06T13:04:57.098704 #45] INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
I, [2015-04-06T13:04:57.204210 #45] INFO -- : CREATE ROLE
I, [2015-04-06T13:04:57.205478 #45] INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2015-04-06T13:04:57.306197 #45] INFO -- : GRANT
I, [2015-04-06T13:04:57.307553 #45] INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2015-04-06T13:04:57.406860 #45] INFO -- : ALTER SCHEMA
I, [2015-04-06T13:04:57.408347 #45] INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists hstore;"'
I, [2015-04-06T13:04:57.534395 #45] INFO -- : CREATE EXTENSION
I, [2015-04-06T13:04:57.536087 #45] INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists pg_trgm;"'
I, [2015-04-06T13:04:57.646119 #45] INFO -- : CREATE EXTENSION
I, [2015-04-06T13:04:57.647680 #45] INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists hstore;"'
I, [2015-04-06T13:04:57.773218 #45] INFO -- : CREATE EXTENSION
I, [2015-04-06T13:04:57.774521 #45] INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists pg_trgm;"'
I, [2015-04-06T13:04:57.885054 #45] INFO -- : CREATE EXTENSION
I, [2015-04-06T13:04:57.887659 #45] INFO -- : > sudo -u postgres psql discourse
I, [2015-04-06T13:04:57.901331 #45] INFO -- : update pg_database set encoding = pg_char_to_encoding('UTF8') where datname = 'discourse' AND encoding = pg_encoding_to_char('SQL_ASCII');
2015-04-06 13:04:57 UTC [214-1] postgres@discourse ERROR: invalid input syntax for integer: "SQL_ASCII" at character 126
2015-04-06 13:04:57 UTC [214-2] postgres@discourse STATEMENT: update pg_database set encoding = pg_char_to_encoding('UTF8') where datname = 'discourse' AND encoding = pg_encoding_to_char('SQL_ASCII');
LINE 1: ... = 'discourse' AND encoding = pg_encoding_to_char('SQL_ASCII...
I, [2015-04-06T13:04:58.024196 #45] INFO -- : File > /var/lib/postgresql/take-database-backup chmod: +x
I, [2015-04-06T13:04:58.040752 #45] INFO -- : File > /var/spool/cron/crontabs/postgres chmod:
I, [2015-04-06T13:04:58.041634 #45] INFO -- : > echo postgres installed!
I, [2015-04-06T13:04:58.056435 #45] INFO -- : postgres installed!
I, [2015-04-06T13:04:58.087539 #45] INFO -- : File > /etc/service/redis/run chmod: +x
I, [2015-04-06T13:04:58.117823 #45] INFO -- : File > /etc/runit/3.d/10-redis chmod: +x
I, [2015-04-06T13:04:58.119364 #45] INFO -- : Replacing daemonize yes with in /etc/redis/redis.conf
I, [2015-04-06T13:04:58.120657 #45] INFO -- : Replacing (?-mix:^pidfile.*$) with in /etc/redis/redis.conf
I, [2015-04-06T13:04:58.122196 #45] INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2015-04-06T13:04:58.137861 #45] INFO -- :
I, [2015-04-06T13:04:58.138601 #45] INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2015-04-06T13:04:58.139669 #45] INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2015-04-06T13:04:58.141051 #45] INFO -- : > echo redis installed
I, [2015-04-06T13:04:58.154658 #45] INFO -- : redis installed
I, [2015-04-06T13:04:58.155731 #45] INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2015-04-06T13:04:58.242444 #45] INFO -- : Aborting! Mail is not configured!
I, [2015-04-06T13:04:58.242960 #45] INFO -- : Terminating async processes
I, [2015-04-06T13:04:58.243120 #45] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/9.3/bin/postmaster -D /etc/postgresql/9.3/main pid: 115
2015-04-06 13:04:58 UTC [115-2] LOG: received fast shutdown request
2015-04-06 13:04:58 UTC [115-3] LOG: aborting any active transactions
2015-04-06 13:04:58 UTC [122-2] LOG: autovacuum launcher shutting down
2015-04-06 13:04:58 UTC [119-1] LOG: shutting down
2015-04-06 13:04:58 UTC [119-2] LOG: database system is shut down
FAILED
RuntimeError: /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end' failed with return #<Process::Status: pid 225 exit 1>
Location of failure: /pups/lib/pups/exec_command.rb:105:in `spawn'
exec failed with the params "/usr/local/bin/ruby -e 'if ENV[\"DISCOURSE_SMTP_ADDRESS\"] == \"smtp.example.com\"; puts \"Aborting! Mail is not configured!\"; exit 1; end'"
2a8849eeaf33bc6a452bdf0bcc6427707ed7e05873719f70a60cbc896f2d570e
FAILED TO BOOTSTRAP
