Cloud installation is not working
The discussion revolves around the issue of a failed Discourse installation using the official installation guide. jucajuca shared the error logs and attempted to troubleshoot with the help of other users. It was initially suspected that the issue was related to disk space, but Falco pointed out the error message actually mentioned a disk quota issue. jucajuca checked the disk space and quotas, but the issue persisted.
jucajuca eventually opted for the Bitnami installation method, which was successful in installing the plugins. However, this solution was not recommended by other users, such as JammyDodger, who suggested that unsupported install methods should not be recommended. Other users, like Alexander and itsbhanusharma, shared their own experiences with different installation methods, highlighting the importance of following the official installation guide for a clean and supported setup.
I am following the instructions to install discourse. There is plenty of space in the machine, so I don’t understand why does the installation fail.
x86_64 arch detected.
Fetching origin
Launcher is up-to-date
/usr/local/lib/ruby/gems/2.7.0/gems/pups-1.1.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2022-04-02T15:52:39.697036 #1]  INFO -- : Reading from stdin
I, [2022-04-02T15:52:39.702390 #1]  INFO -- : > locale-gen $LANG && update-locale
I, [2022-04-02T15:52:39.733464 #1]  INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2022-04-02T15:52:39.733795 #1]  INFO -- : > mkdir -p /shared/postgres_run
I, [2022-04-02T15:52:39.737797 #1]  INFO -- :
I, [2022-04-02T15:52:39.737932 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2022-04-02T15:52:39.740245 #1]  INFO -- :
I, [2022-04-02T15:52:39.740430 #1]  INFO -- : > chmod 775 /shared/postgres_run
I, [2022-04-02T15:52:39.743139 #1]  INFO -- :
I, [2022-04-02T15:52:39.743292 #1]  INFO -- : > rm -fr /var/run/postgresql
I, [2022-04-02T15:52:39.745920 #1]  INFO -- :
I, [2022-04-02T15:52:39.746113 #1]  INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2022-04-02T15:52:39.748826 #1]  INFO -- :
I, [2022-04-02T15:52:39.749009 #1]  INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2022/04/02 15:52:39 socat[20] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2022-04-02T15:52:39.755028 #1]  INFO -- :
I, [2022-04-02T15:52:39.755329 #1]  INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2022-04-02T15:52:39.759007 #1]  INFO -- :
I, [2022-04-02T15:52:39.759160 #1]  INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2022-04-02T15:52:39.761649 #1]  INFO -- :
I, [2022-04-02T15:52:39.761753 #1]  INFO -- : > mkdir -p /shared/postgres_run/13-main.pg_stat_tmp
I, [2022-04-02T15:52:39.764155 #1]  INFO -- :
I, [2022-04-02T15:52:39.764354 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run/13-main.pg_stat_tmp
I, [2022-04-02T15:52:39.766597 #1]  INFO -- :
I, [2022-04-02T15:52:39.771178 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2022-04-02T15:52:39.775520 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2022-04-02T15:52:39.780150 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2022-04-02T15:52:39.787459 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2022-04-02T15:52:39.788516 #1]  INFO -- : > chown -R root /var/lib/postgresql/13/main
I, [2022-04-02T15:52:40.473746 #1]  INFO -- :
I, [2022-04-02T15:52:40.474202 #1]  INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/13/bin/initdb -D /shared/postgres_data || exit 0
I, [2022-04-02T15:52:40.477125 #1]  INFO -- :
I, [2022-04-02T15:52:40.477219 #1]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2022-04-02T15:52:40.486100 #1]  INFO -- :
I, [2022-04-02T15:52:40.486352 #1]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2022-04-02T15:52:40.488833 #1]  INFO -- :
I, [2022-04-02T15:52:40.489078 #1]  INFO -- : > /root/upgrade_postgres
I, [2022-04-02T15:52:40.492944 #1]  INFO -- :
I, [2022-04-02T15:52:40.493085 #1]  INFO -- : > rm /root/upgrade_postgres
I, [2022-04-02T15:52:40.495214 #1]  INFO -- :
I, [2022-04-02T15:52:40.495535 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2022-04-02T15:52:40.496011 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2022-04-02T15:52:40.496486 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2022-04-02T15:52:40.496888 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2022-04-02T15:52:40.497209 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2022-04-02T15:52:40.497544 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2022-04-02T15:52:40.497840 #1]  INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2022-04-02T15:52:40.500782 #1]  INFO -- :
I, [2022-04-02T15:52:40.501121 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2022-04-02T15:52:40.501372 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2022-04-02T15:52:40.501752 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2022-04-02T15:52:40.502059 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/13/main/pg_hba.conf
I, [2022-04-02T15:52:40.502326 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2022-04-02T15:52:40.502663 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2022-04-02T15:52:40.503023 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2022-04-02T15:52:40.504697 #1]  INFO -- : > sleep 5
2022-04-02 15:52:40.605 UTC [43] LOG:  starting PostgreSQL 13.6 (Debian 13.6-1.pgdg110+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
2022-04-02 15:52:40.605 UTC [43] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2022-04-02 15:52:40.605 UTC [43] LOG:  listening on IPv6 address "::", port 5432
2022-04-02 15:52:40.607 UTC [43] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2022-04-02 15:52:40.610 UTC [46] LOG:  database system was shut down at 2022-04-02 15:41:15 UTC
2022-04-02 15:52:40.614 UTC [43] LOG:  database system is ready to accept connections
I, [2022-04-02T15:52:45.507830 #1]  INFO -- :
I, [2022-04-02T15:52:45.508198 #1]  INFO -- : > su postgres -c 'createdb discourse' || true
2022-04-02 15:52:45.562 UTC [56] postgres@postgres ERROR:  database "discourse" already exists
2022-04-02 15:52:45.562 UTC [56] postgres@postgres STATEMENT:  CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR:  database "discourse" already exists
I, [2022-04-02T15:52:45.564128 #1]  INFO -- :
I, [2022-04-02T15:52:45.564530 #1]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
2022-04-02 15:52:45.613 UTC [60] postgres@discourse ERROR:  role "discourse" already exists
2022-04-02 15:52:45.613 UTC [60] postgres@discourse STATEMENT:  create user discourse;
I, [2022-04-02T15:52:45.616039 #1]  INFO -- :
I, [2022-04-02T15:52:45.616483 #1]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2022-04-02T15:52:45.664962 #1]  INFO -- : GRANT
I, [2022-04-02T15:52:45.665420 #1]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2022-04-02T15:52:45.711994 #1]  INFO -- : ALTER SCHEMA
I, [2022-04-02T15:52:45.712718 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists hstore;"'
NOTICE:  extension "hstore" already exists, skipping
I, [2022-04-02T15:52:45.763337 #1]  INFO -- : CREATE EXTENSION
I, [2022-04-02T15:52:45.763727 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists pg_trgm;"'
NOTICE:  extension "pg_trgm" already exists, skipping
I, [2022-04-02T15:52:45.811148 #1]  INFO -- : CREATE EXTENSION
I, [2022-04-02T15:52:45.811604 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists hstore;"'
I, [2022-04-02T15:52:45.860908 #1]  INFO -- : CREATE EXTENSION
I, [2022-04-02T15:52:45.861252 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists pg_trgm;"'
I, [2022-04-02T15:52:45.916601 #1]  INFO -- : CREATE EXTENSION
I, [2022-04-02T15:52:45.916896 #1]  INFO -- : > sudo -u postgres psql discourse
I, [2022-04-02T15:52:45.923402 #1]  INFO -- : update pg_database set encoding = pg_char_to_encoding('UTF8') where datname = 'discourse' AND encoding = pg_char_to_encoding('SQL_ASCII');
I, [2022-04-02T15:52:45.976960 #1]  INFO -- : File > /var/lib/postgresql/take-database-backup  chmod: +x  chown: postgres:postgres
I, [2022-04-02T15:52:45.979632 #1]  INFO -- : File > /var/spool/cron/crontabs/postgres  chmod:   chown:
I, [2022-04-02T15:52:45.979720 #1]  INFO -- : > echo postgres installed!
I, [2022-04-02T15:52:45.981659 #1]  INFO -- : postgres installed!
I, [2022-04-02T15:52:45.986510 #1]  INFO -- : File > /etc/service/redis/run  chmod: +x  chown:
I, [2022-04-02T15:52:45.993146 #1]  INFO -- : File > /etc/service/redis/log/run  chmod: +x  chown:
I, [2022-04-02T15:52:45.997735 #1]  INFO -- : File > /etc/runit/3.d/10-redis  chmod: +x  chown:
I, [2022-04-02T15:52:45.997900 #1]  INFO -- : Replacing daemonize yes with  in /etc/redis/redis.conf
I, [2022-04-02T15:52:45.998373 #1]  INFO -- : Replacing (?-mix:^pidfile.*$) with  in /etc/redis/redis.conf
I, [2022-04-02T15:52:46.015498 #1]  INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2022-04-02T15:52:46.018440 #1]  INFO -- :
I, [2022-04-02T15:52:46.019127 #1]  INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2022-04-02T15:52:46.019741 #1]  INFO -- : Replacing (?-mix:^bind .*$) with  in /etc/redis/redis.conf
I, [2022-04-02T15:52:46.020129 #1]  INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2022-04-02T15:52:46.020727 #1]  INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2022-04-02T15:52:46.021144 #1]  INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2022-04-02T15:52:46.021523 #1]  INFO -- : > echo redis installed
I, [2022-04-02T15:52:46.026032 #1]  INFO -- : redis installed
I, [2022-04-02T15:52:46.026300 #1]  INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2022-04-02T15:52:46.031069 #1]  INFO -- : logfile ""
I, [2022-04-02T15:52:46.031450 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2022-04-02T15:52:46.034586 #1]  INFO -- : > sleep 10
104:C 02 Apr 2022 15:52:46.039 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
104:C 02 Apr 2022 15:52:46.039 # Redis version=6.2.6, bits=64, commit=00000000, modified=0, pid=104, just started
104:C 02 Apr 2022 15:52:46.039 # Configuration loaded
104:M 02 Apr 2022 15:52:46.040 * monotonic clock: POSIX clock_gettime
104:M 02 Apr 2022 15:52:46.040 * Running mode=standalone, port=6379.
104:M 02 Apr 2022 15:52:46.040 # WARNING: The TCP backlog setting of 511 cannot be enforced because /proc/sys/net/core/somaxconn is set to the lower value of 128.
104:M 02 Apr 2022 15:52:46.040 # Server initialized
104:M 02 Apr 2022 15:52:46.040 # WARNING overcommit_memory is set to 0! Background save may fail under low memory condition. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
104:M 02 Apr 2022 15:52:46.041 * Loading RDB produced by version 6.2.6
104:M 02 Apr 2022 15:52:46.041 * RDB age 691 seconds
104:M 02 Apr 2022 15:52:46.041 * RDB memory usage when created 0.77 Mb
104:M 02 Apr 2022 15:52:46.041 # Done loading RDB, keys loaded: 0, keys expired: 0.
104:M 02 Apr 2022 15:52:46.041 * DB loaded from disk: 0.000 seconds
104:M 02 Apr 2022 15:52:46.041 * Ready to accept connections
I, [2022-04-02T15:52:56.037154 #1]  INFO -- :
I, [2022-04-02T15:52:56.037408 #1]  INFO -- : > thpoff echo "thpoff is installed!"
I, [2022-04-02T15:52:56.042684 #1]  INFO -- : thpoff is installed!
I, [2022-04-02T15:52:56.043143 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2022-04-02T15:52:56.105740 #1]  INFO -- :
I, [2022-04-02T15:52:56.106083 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2022-04-02T15:52:56.169145 #1]  INFO -- :
I, [2022-04-02T15:52:56.169517 #1]  INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2022-04-02T15:52:56.234968 #1]  INFO -- :
I, [2022-04-02T15:52:56.235333 #1]  INFO -- : > rm -f /etc/cron.d/anacron
I, [2022-04-02T15:52:56.240081 #1]  INFO -- :
I, [2022-04-02T15:52:56.243834 #1]  INFO -- : File > /etc/cron.d/anacron  chmod:   chown:
I, [2022-04-02T15:52:56.250049 #1]  INFO -- : File > /etc/runit/1.d/copy-env  chmod: +x  chown:
I, [2022-04-02T15:52:56.256290 #1]  INFO -- : File > /etc/service/unicorn/run  chmod: +x  chown:
I, [2022-04-02T15:52:56.262240 #1]  INFO -- : File > /etc/service/nginx/run  chmod: +x  chown:
I, [2022-04-02T15:52:56.269390 #1]  INFO -- : File > /etc/runit/3.d/01-nginx  chmod: +x  chown:
I, [2022-04-02T15:52:56.274005 #1]  INFO -- : File > /etc/runit/3.d/02-unicorn  chmod: +x  chown:
I, [2022-04-02T15:52:56.274108 #1]  INFO -- : Replacing # postgres with sv start postgres || exit 1 in /etc/service/unicorn/run
I, [2022-04-02T15:52:56.274326 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2022-04-02T15:52:56.276941 #1]  INFO -- : > cd /var/www/discourse && git reset --hard
131:C 02 Apr 2022 15:52:56.281 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
131:C 02 Apr 2022 15:52:56.281 # Redis version=6.2.6, bits=64, commit=00000000, modified=0, pid=131, just started
131:C 02 Apr 2022 15:52:56.281 # Configuration loaded
131:M 02 Apr 2022 15:52:56.282 * monotonic clock: POSIX clock_gettime
131:M 02 Apr 2022 15:52:56.282 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
131:M 02 Apr 2022 15:52:56.282 # Failed listening on port 6379 (TCP), aborting.
fatal: Unable to create '/var/www/discourse/.git/index.lock': Disk quota exceeded
I, [2022-04-02T15:52:56.287140 #1]  INFO -- :
I, [2022-04-02T15:52:56.287581 #1]  INFO -- : Terminating async processes
I, [2022-04-02T15:52:56.287626 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 43
2022-04-02 15:52:56.287 UTC [43] LOG:  received fast shutdown request
104I, [2022-04-02T15:52:56.287845 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 104
:signal-handler (1648914776) Received SIGTERM scheduling shutdown...
2022-04-02 15:52:56.288 UTC [43] LOG:  aborting any active transactions
2022-04-02 15:52:56.293 UTC [43] LOG:  background worker "logical replication launcher" (PID 52) exited with exit code 1
2022-04-02 15:52:56.294 UTC [47] LOG:  shutting down
2022-04-02 15:52:56.356 UTC [43] LOG:  database system is shut down
104:M 02 Apr 2022 15:52:56.373 # User requested shutdown...
104:M 02 Apr 2022 15:52:56.373 * Saving the final RDB snapshot before exiting.
104:M 02 Apr 2022 15:52:56.374 * DB saved on disk
104:M 02 Apr 2022 15:52:56.374 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && git reset --hard failed with return #<Process::Status: pid 133 exit 128>
Location of failure: /usr/local/lib/ruby/gems/2.7.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"code", "cmd"=>["git reset --hard", "git clean -f", "git remote set-branches --add origin main", "git remote set-branches origin $version", "git fetch --depth 1 origin $version", "git checkout $version", "mkdir -p tmp", "chown discourse:www-data tmp", "mkdir -p tmp/pids", "mkdir -p tmp/sockets", "touch tmp/.gitkeep", "mkdir -p                    /shared/log/rails", "bash -c \"touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log\"", "bash -c \"ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log $home/log\"", "bash -c \"mkdir -p           /shared/{uploads,backups}\"", "bash -c \"ln    -s           /shared/{uploads,backups} $home/public\"", "bash -c \"mkdir -p           /shared/tmp/{backups,restores}\"", "bash -c \"ln    -s           /shared/tmp/{backups,restores} $home/tmp\"", "chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp", "find public/plugins/ -maxdepth 1 -xtype l -delete"]}
bootstrap failed with exit code 128
You have a disk space problem.
Is there some other issues too than just disk? It sounds like Redis is already in use and so much I know, even I’m not anykind expert, that example.com can’t work.
What kind VPS do you have in use?
I don’t think so:
df -h
udev            7.9G     0  7.9G   0% /dev
tmpfs           1.6G  158M  1.5G  10% /run
/dev/sda3       314G   46G  256G  16% /
tmpfs           7.9G     0  7.9G   0% /dev/shm
tmpfs           5.0M     0  5.0M   0% /run/lock
tmpfs           7.9G     0  7.9G   0% /sys/fs/cgroup
/dev/sda2       976M   81M  829M   9% /boot
overlay         314G   46G  256G  16% /mnt/STORAGE01/DOCKER/overlay2/2b567ad99a28184ead30baec7f5844d07236b06f4ef16b0a9ca966b882e767be/merged
overlay         314G   46G  256G  16% /mnt/STORAGE01/DOCKER/overlay2/ffe9ac16654aab1ce7faa0f86a6838ebc8742d1e822f983899fc65773932891b/merged
shm              64M     0   64M   0% /mnt/STORAGE01/DOCKER/containers/4c6eb2189b6fb62317a60ce17913353c15d3788dd830ca2e8969dac0c6cb0a78/mounts/shm
tmpfs           1.6G     0  1.6G   0% /run/user/0
overlay         314G   46G  256G  16% /mnt/STORAGE01/DOCKER/overlay2/1b877dae7a26b14bbc15b251167b941b2b226b6e338f83f9d13291837453fe33/merged
overlay         314G   46G  256G  16% /mnt/STORAGE01/DOCKER/overlay2/42b8c79a4d2c01b7397da50e3cf8b4971db3c442954c7184a871a490df814ece/merged
overlay         314G   46G  256G  16% /mnt/STORAGE01/DOCKER/overlay2/8bf85f66333d7f903b6f93a971bd019c57818d0092fbb6d5ac9283f28c0b6f40/merged
overlay         314G   46G  256G  16% /mnt/STORAGE01/DOCKER/overlay2/355373ffad468e175447bad52ea2ee04d1fdb6d2fbc3b2d3e3811e7eda111bd6/merged
The error message was disk quota, not disk space. Might you have a quota set?
Is this the same server as your earlier bitnami installation, or a fresh VPS?
I followed the instructions of discourse. I never got it working.
went back to the bitnami metod and I managed to install the plugins. I my humble opinion the bitnami option is less convoluted than building the docker images from scratch.
I must say that in the past I tried the Bitnami installations and I could not understand them at all, in fact for some reason the Discourse data was deleted after a few hours :pouting_cat::thinking:
On the contrary, with the official installation of Discourse on a clean server maximum it takes me 20 minutes and so far everything works perfectly :grin:
But, for tastes there are colors
I can understand your feeling, I would have said the same about digitalocean 1 click installer if You’d have asked me 5 years ago. However, once I’ve had a hold of installation process, everything was that much more easier and customizable (not to say, much more supported by discourse team) I’d highly recommend you try the official installation by following the installation guide on a spec that’s recommended and you’ll probably like it better.
Could you please let me know how did you solve this problem? :smiling_face_with_tear:
It sounds like they opted for an unsupported install, so their solution wouldn’t be recommended on here.
But if you’re having issues getting a standard install up and running please feel free to start a new #installation topic with details of the problem and I’m sure we can offer you some advice. :+1:
