i installed 3 themes (Category Icons,
Header Links Theme Component and
Users Top Nav) but didnt showed up on my site but only the Header Links Theme Component showed only on the preview. Any help please?
Il componente tema Users Top Nav è attualmente non funzionante e necessita di un aggiornamento. Ecco perché è stato inserito nella categoria #customization:theme:broken-theme.
Potrebbe essere la causa del problema che stai riscontrando. Puoi provare a rimuoverlo e verificare nuovamente?
ok what about the other 2 themes ? why not showing on my site? are they broken also?
They aren’t themes, they’re theme components.
Once you install them you select a theme and use the drop-down at the bottom of said theme to add/enable them.
Are they enabled? Are you testing the theme you enabled them in?
Which discourse version is it?
Did you configure the category icons component? That component doesn’t do anything unless you enter some details in the settings. Feel free to post a screenshot.
Did You add them to your primary theme as a component?
yes i did not still working
Once You’ve enabled them, you have to refresh your browser for the changes to take effect. If it still doesn’t work for You, You’d need to provide what version of discourse you’re running.
i refreshed many times yet nothing worked. im using version 2.1.8
It’s a bit difficult to debug the issue without being able to look at your site and check for errors.
If your site is public, please post the url as that would make it easier to find where the problem is.
(you can PM the link to me if it’s not public)
This is because your site is out of date @dave_odiakaose – update to latest
thanks for the assistance:)
