When enabling the watched words regular expressions setting, invalid regular expressions break the specific watched word category entirely.
Reproduction steps
- Enable ‘watched words regular expressions’
- Add a watched word pattern to ‘Require Approval’, e.g.
same issue. - Add an invalid watched word pattern, e.g.
*ban*(as would be the case when having wildcards in watched words before enabling regular expressions). - Note that a post containing ‘same issue’ will skip the approval queue, and will be ignored by the ‘Test’ form too.
- Remove the invalid watched word.
- Note that ‘same issue’ will now correctly match.
Reproduction steps (worse):
- Enable ‘watched words regular expressions’ and tags
- Add an invalid watched word pattern to ‘Tag’, e.g.
*tebex.io*→paid. - Try posting a new topic. This will return ‘Error 500’ with the following result in
/logs:
RegexpError (target of repeat operator is not specified: /*tebex.io*/)
app/services/word_watcher.rb:116:in `initialize'
app/services/word_watcher.rb:116:in `new'
app/services/word_watcher.rb:116:in `matches?'
lib/topic_creator.rb:184:in `block in setup_tags'
lib/topic_creator.rb:183:in `each'
lib/topic_creator.rb:183:in `setup_tags'
lib/topic_creator.rb:46:in `create'
lib/post_creator.rb:501:in `create_topic'
Footnote
I think it’d be nice if having regular expressions disabled could still allow a valid regex to be entered similar to wildcards if, say, wrapped in a / block, especially since the toggle will break in a bad way if any old watched words already have wildcards.
