iOS : Coller des images avec CMD+V
Would be super nice to have this supported.
Thanks.
It already works if you touch and hold to paste.
I just used tap and hold to copy, then tap and hold to paste that on my iPad Pro.
4 « J'aime »
Touch and hold to paste is nice but it’s not the same as CMD-V. That being said, at the time of this writing, CMD+V does indeed work. Perhaps @sam fixed something?
1 « J'aime »
Did not touch anything BUT if you clicked the “I am using a real keyboard” setting a big pile of hacks are removed, that could indeed fix the issue.
3 « J'aime »
Super. Yes, it does indeed work now.
But I’m a little confused because if I screenshot the page, I think I should be able to select “Copy” on the screenshot and then paste it into the textarea. But CMD+V does nothing, and when holding, the “Paste” option does not appear. Perhaps the screenshots are a special format that you don’t support yet? Or something.
You mentioned “cut and paste of images on iPad” in the other thread being a priority so I thought I might add this. The ability to quickly screenshot and paste into Discourse is obviously a power feature that I love, but I recognize it may be niche.
As always, thanks for listening.
Are you able to paste screenshots to other sites from iOS? I’ve tried a few (where I know it works on macOS) and it doesn’t seem to work anywhere…
1 « J'aime »
Good question. Yes, the composers of WordPress, Ghost and Medium are some examples of where this works.
Snap a screenshot, long-press, hit “Copy”, then paste into the textarea.
2 « J'aime »
